Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Dh-145 replace wick kerosene heater - Reddy Heater-170,000 BTU Kerosene Deluxe
1 Related Answer
hardrocko
Kim Yearick
  • 1476 Answers
SOURCE: Is it true that if you use moth balls with the
I can't answer about moth balls cleaning the wick but off the top of my head I would not try it as I do not know just what gases your unit would give off. I use kerosene heaters and find that after about 5 tanks of fuel I put on a pair of household rubber gloves, remove the chimney and turn the wick all the way up. Then I roll the wick between my fingers and get the hard carbon off. Once I have the wick clean I use the shop vac to vacuum it all up. I have found that by doing this my wick is never dirty, I do not get any smoke and the wicks last more than 20 years. Probably a better idea than moth balls. Let me know how you make out.
hardrocko
Posted on Feb 10, 2010
How do replace the wick in a turco kerosene heater
This a very odd question about cell phones, isn't it? There are two videos on you tube to help you do this.
Kerosene Heater Wick Replace - YouTube
How To Replace a Kerosene Heater Wick Tutorial - YouTube
Jan 26, 2014 | Lands Phones
Need to see pictorial instruction on how to replace wick in a Dyna Glo RMC-95-C2 kerosene heater
I think the Dyna-glow RMC95 series of heaters are equivalent to DH2300 series heaters.
In any event, the wick you purchased should have ahd the installation instructions included with the wick.
If it didn't or you tossed it, Here's a link to the DH-2300 series heater's Owners Manual, which may help you.
http://www.yourheater.com/DH2301-3%20owners%20manual.pdf
Good luck. Be sure to wear rubber gloves when you try to install the wick. Particularly, if you still have kerosene in the tank.
Feb 11, 2011 | Dyna-Glo RMC-8001SS Heater
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
RMC-95C6 wick replacement
REPLACEMENT WICK NUMBER: Kero-World 32225, Dura Heat DH-145, Glowick 30856.
Sep 07, 2009 | Dyna-Glo RMC-8001SS Heater
I need to buy a replacement wick
You can get them at Lowes for less then $10.00 Number DH-145
Dec 23, 2008 | Dyna-Glo RMC-8001SS Heater
Why am I replacing wicks every 3 weeks
could be you got the flame a little too high so its burning off the top of the wick.
Dec 27, 2007 | Corona 23-DK Compact Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
