Question about Lexmark X Office Equipment & Supplies
SOURCE: 13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Posted on Jul 23, 2009
SOURCE: HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green
check until you see Information Menu. Scroll using arrows until you see
Print Menu Map then press green check. If it prints from tray 1, your
problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Posted on Jul 25, 2009
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
SOURCE: HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Posted on Sep 18, 2009
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Posted on Nov 27, 2009
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Oct 20, 2011 | Sharp MX-2300N Color Copier
Feb 10, 2011 | HP LaserJet 1320 Printer
Apr 21, 2010 | HP Office Equipment & Supplies
Jun 25, 2009 | HP LaserJet 4700 Printer
Apr 13, 2009 | HP LaserJet 5000dn Printer
Jun 11, 2008 | HP LaserJet 4600dn Color Printer
May 24, 2008 | Brother HL-2040 Laser Printer
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
when you go to the menu of the printer is the paper TYPE set correctly?
tray 2 should be letter ( if using plain paper)
tray 3 legal, label etc...
and tray 1 should be any
May 18, 2007 | IBM Infoprint 1140 Laser Printer
Oct 16, 2019 | Lexmark Office Equipment & Supplies
238 people viewed this question
