Question about GE 30 in. JGP337 Gas Cooktop
Igniters work isnot ignite
ELECTRONIG IGNITION DOES NOT WORK TO IGNITE THE COOKTOP I HAVE TO USE MATCHES TO IGNITE THE GAS
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Apr 04, 2011 | Bosch 30 in. NGP74 Gas Cooktop
Gas comes on but no fire comes out when knob turns on. must light manually
ur igniter is not working either the igniter wire or the transformer...igniter wire is in the buner base color white ceramic that the igniter wire..if is broken pelace it..check all the igniter wire...if no sound it is igniter transformer...its expensive to replase the igniter transformer.
Jan 13, 2010 | Cooktops
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Model#ZGU661 electric igniter works intermittenly
How old is the stove? The igniter does sometimes go bad. Also you need to check the igniter wires. The igniter works on a grounding principal so if the wires outside shield are cracked or eaten by mice the spark then travels to the path of least resistance and probably sparks under the top.
Good Luck
Oct 21, 2009 | GE Cooktops
KitchenAid KGCS100SAL0 Gas Range Top, one igniter doesn't work
change the ignighter switch they are mounted to the front of the knobs and must be changed as a set they look like square plastic boxes after you remove the knobs and pull the panel off the front
Jan 28, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Ignitors are not working
Nov 17, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Igniters will not work
did the water fall on the spark module do you hear a faint click ,igniters dont go bad if they get wet if you say theres power going to the cooktop then you might have a bad spark module.
Dec 24, 2007 | Kenmore 36 in. 33384 / 33385 / 33389 Gas...
Jennair CCG2523 Gas Cooktop
igniters fire continully any time knobs are on, even after burners
are lighted.
Sep 18, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
GE 30 in. JGP337 Gas Cooktop Logo
51 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
