Question about Sharp R-1610 Microwave Oven
Microwave quit Remove old microwave
2 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Microwave runs fine - heats nothing
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk We are the ones who repair the displays and control boards, by the way.
Posted on Sep 23, 2007
Anonymous
SOURCE: Where is the light bulb in an old Sharp Carousel Microwave?
Microwave_svc's site is awesome! I was able to get all the help I needed for a similar Sharp Carousel microwave. My bulb was simply loose in the socket base causing intermittent bulb lighting. Microwave_svc's helpful links got me to the service manual and, along with a nice set of "tamper-proof" screw compatible TORX bits I bought at HarborFreight, I was easily able to get cover off, remove bulb socket, tighten bulb, re-install bulb socket, button unit back up, and, voila, the light now works without intermittent blinking. FIXYA!!!!
Many thanks to guru microwave_svc!!!!!!!
Posted on Oct 13, 2008
6 year old Panasonic 1250W High Power Inverter Microwave Oven (Model NN-S954WF) Manufactured May 2004 has completely died. Wondering what might be the problem and is it fixable or should we just get a...
These early inverter microwaves blew their high current power transistors quite regularly. These high current power transistors are quite expensive to replace, and if one blows, there is a likelyhood of others blowing. As the microwave is over 13 years old, I'd suggest getting a new one. Inverter technology in microwaves is now a mature technology, resulting in reasonable prices and much improved reliability.
Nov 12, 2017 | Panasonic NN-S954WF Microwave Oven
Microwave works except not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
djh
May 08, 2010 | Bosch HMV9305 Microwave Oven
Kenmore microwave's exterior and buttons
Hi it is quite normal for the outside of a microwave oven to get quite warm to the touch. with regard to the buttons not working; this will be due to a faulty touch panel mebrane that will need to be replaced. They are not too expensive so is a viable repair
Hope this helps
Jan 07, 2010 | Microwave Ovens
Microwave is 21 years old. It is above the range
Um, no. You can get a new microwave that is much, much more efficient for a fraction of the repair cost.
Nov 09, 2009 | Whirlpool MH7135XE Microwave Oven
Jenn-Air M166 quit, no power
Took microwave out, opened back, 15amp fuse blown. Replaced all ok.
Jul 06, 2009 | Microwave Ovens
WE BLEW 2 OUTLETS IN KITCHEN & COULDNT FIND THE BREAKER THAT BLEW
remove cover of microwave, find and check the fuse
Feb 05, 2009 | Microwave Ovens
Sharp R-1610 Microwave Oven Logo
22 people viewed this question
Top Sharp Microwave Ovens Experts
Michael Thomas
Michael Thomas
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
