E5 - Error Code E5 Error code indicates that the water collection tank is full. To drain the water collection tank completely, leave the bottom drain cap off long enough to allow any residual water to drain out. Once the water tank is completely drained and no more water flows out, reinstall the cap
Fisher and Paykel Dishwasher Dishdrawer Error Code E5 = The first 3 program indicator lights are flashing. Error Code Cause: Water supply hose is crimped or bent. Drain hose is too low. Water tap not turned on. Not enough water supply pressure.
https://removeandreplace.com/2016/06/07/fisher-and-paykel-dishwasher-dishdrawer-error-codes-and-troubleshooting-how-to-fix/
Error code 5 means : Required temperature not reached. Causes/Trubleshooting
Thermoblock has blown - replace thermoblock. Power electronics is defective - replace the triacs of the power board or the whole power board. Attention - determine resistance value of the Thermoblock to avoid subsequent errors.
E1: tape end detection LED open E2: front loading motor lock E3: loading motor lock E4: cylinder motor lock E5: reel motor lock These are from a Panasonic AG-7500 service manual.
e-5 means that the unit is 10 degrees warmer then setpoint. If you just close everything up and let it run the e5 should disappear when it gets within the temperature.
