Frigidaire ATF6000ES Front Load Washer Logo
j
juan Posted on Jan 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E11 error code
The machine starts and then pauses after a while, I have to start the machine several times to get one load.
  • Official Brand Answer 4,342 Answers
  • Posted on Jan 16, 2014
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1466562
Points
5907
Good Morning Juan, thank you for allowing me to assist you!
Generally, error code E11 indicates that your washing machine is taking a long time to fill (or is continuing to fill).
    ·Is the incoming water flow normal? If it is, does the fill water continue to enter the washer? If yes, disconnect power from your washing machine. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
    ·If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
    ·If you have checked all of the above, your washer may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
5 Related Answers
Anonymous
  • 413 Answers
  • Posted on Jun 15, 2008
SOURCE: error code
'dr' is an error code that indicates the door is not closed. If closing properly the door lock may have to be replaced.
Anonymous
  • 1531 Answers
  • Posted on Sep 19, 2009
SOURCE: Frigidaire Washer stuck on pause
does the unit have standing water still in it.if so use a shop vac and attach it to the end of the drain hoseand removed all the water the check you drain pump for any kind of foriegn object that may be stopping the impellar wheel.the door lock may also be bad, the last but maybe the first thing is a bad control board
Jim Wirth
  • 100 Answers
  • Posted on Dec 01, 2009
SOURCE: keep stopping pausing
If you leave the machine to itself, will it go through the whole wash satisfactorily? If it does, then the start and stop is designed into it. What it is doing is stopping and reversing the washing action. That is so the clothes will not wind up in a long rope shape, like the winding up of a towel like you use to do to a towel to snap your bother or sister in the showers or at the pool. It UNWINDS the load... It goes a few turns one way, then pauses, then a few turns the other way and pauses. Hope this helps..... 2529817.gif
Anonymous
  • 141 Answers
  • Posted on Dec 24, 2009
SOURCE: FAFW3577KWO washer-code E11
Your machine may have short circuit with the inlet valve since you are facing problem after 5 to 6 mins you are suppose to change the inlet valve
Anonymous
  • 613 Answers
  • Posted on Nov 20, 2010
SOURCE: pause code then error code on Affiinity front load
You will have to call up an appliance place or maybe get lucky and call up Frigidaire. They will give you reset code. Don't let them charge you for this.
2answers
My frigidaire washing machine displays E11 error and stops before completing washing cycle. How can I trouble shoot? I plugged and unplug it didn't help
On many machines the E11 error occurs as one or more of these connecting wires break, this may be due to excess movement from unbalanced loads. To prevent this when washing any heavy items ensure there are enough heavy items to spread around the drum to help the machine balance its load.
My stering washing machine is stuck on pause, no error buttons are showing. how do i reset the machine
Try unplugging the machine from the wall, wait a frw minutes and replug it in.
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
I have a Frigidaire affinity washer error code reads E11. Unit immediately pauses after activating start. Troubleshooting door ssitch revealed resistance was 1320 ohms. I was told 1500 ohms should be...
Good Morning Neil, thank you for your post!
Typically, error code E11 indicates that the water fill time is too long. This could be due to a faulty valve, clogged valve filters, kinked inlet hoses, or low water pressure supplied to unit. Also, if the drain hose is installed too deep into the house drain pipe the water may syphon as it fills. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
1helpful
E11 code on the dispay
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
7helpful
2answers
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Buttons:
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
The F! error code keeps coming up when I start my washer
F1 means communication error, the best thing to do is unplug unit for 2 mins and try again
1helpful
E10 error
The E10 error indicates that one of a group of error codes occurred. The specific code could have been one of the following:
E11 - Fill time too long. (See test 1 below)
E13 - Water leak in the tub or air leak in the air bell. (See test 2 below)
E14 - Dispenser drawer reed switch is open. (See test 3 below)
To recall the specific fault code from this group, follow these steps:
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause/Cancel buttons simultaneously
All LEDs will go blank and after a few seconds the control will signal the stored code
Based on the specific error code, follow the specified test and troubleshooting.
The magnet for the dispenser drawer reed switch is shown in the second image below. If this magnet is missing, you will get the E14 code.
Some of the troubleshooting provided is intended for service technicians. Do not conduct any test or troubleshooting that you are not completely confident that you can safely complete. Unplug the washer before accessing internal components.
Good Luck!!
Thanks
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
