Question about Radio Shack Multipurpose Laser Level
How do I remove a stuck battery from my RS laser level?
The manual recommends removing the batteries when the level is not being used. Of course, I didn't do that and now they have leaked and swollen. I got the 1st battery out, but cannot budge the second one. I've tried baking soda to break any chemical seal. What are the chances of the laser working with fresh batteries?
Laser won't turn on.
Could be alot of things. Bad batteries, bad battery contacts. Dead main board, dead compensator.
Clean the battery contacts with acetone and a qtip. in the battery compartment and on the battery door, and install fresh batteries. Good ones, Duracell preferably. If it still wont turn on, you'll need to take it somewhere. Trimble, in their grand wisdom made it so you have to remove the decal on the front, to open the laser. So, that will need replacement even if nothing else does.
Sep 29, 2013 | Spectra Precision Laser LL400 10 Automatic...
My samsung sch-u485 keeps getting stuck on the verizon logo as i try to turn it on and thats where it gets stuck
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 02, 2012 | Cell Phones
How replace battery in stud finder
It is very easy. Open battery compartment at the back and remove old battery and put new one in.
If you get stuck you can download manual from here:
http://www.irwin.com/support-services/product-manuals
Jul 01, 2012 | Strait-Line Intersect Laser Level With...
Tape is stuck inside a technic RS-TR575
This is the biggest reason why I say that the designer of these fancy little door/cradles SHOUL HAVE BEEN SHOT before invention. With a strong longnose plier break the casing of the cassette The Technics that I worked on the lid of this door can be removed from the outside Be careful with the tape itself if the recording is of great value to you that you do not stretch or break the tape. REMOVE all power batteries or mains or both ! then turn the flywheel in the OPPOSITE direction so that the tape can be unwound. You do get empty shells that can be used in the place of the one you gotta break the shell It remains a messy sort of business After you have removed the tape inspect the rolle and capstan shaft are they CLEAN and free running to prevent this from happening again. In the future it is a good habit to fast forward or rewind the tape from end to end.In the user instruction booklet some manufacturers recommend this. If you are scared to damage your machine then get this done by an expert and ask him/her to show you in future.
Jan 21, 2012 | Technics RS-TR575 Single Dual Cassette...
I have an rt7690-2 laser lever, it no longer automatically levels itself, is there a solution to fix this problem?
The last level I repaired was droped and one of the cams was stuck. I was able to open the unit, and loosen the cam so the auto level system worked correctly. These are delecate inside so be carfull and make sure the batteries are removed. It took a couple of min. to level itself, after turning the unit back on.
Sep 01, 2011 | Garden
Spectra Precision l1242 laser level wont power up
Check to see if there is a re-set for the system. There also may be an internal fuse.
Feb 04, 2010 | Spectra Precision Laser 1242-4 Fully Auto...
Remove battery on apc battery back ups rs 1500
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Slide the battery compartment cover off (front bottom cover).
Pull the battery connector connecting the battery to the UPS
Grasp the top and gently pull the battery out of the UPS.
Oct 08, 2009 | APC Back-UPS RS Battery Backup (apw...
How do I open the cabinet of my RS 1000 UPS?
plese see the manual.Remove the back side screw of ups.
Jul 29, 2009 | APC Back-UPS RS Battery Backup (apw...
Laser not working
Sometimes you can repair an item yourself. Using sandpaper or a nail file, remove all of the "gunk" from the contacts that the leaking batteries left. You can then wipe the contacts with a little bit of alcohol to clean them up and your level should be a good as new.
May 14, 2009 | Measuring Tools & Sensors
Radio Shack Multipurpose Laser Level Logo
254 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
Harrie
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
