Also be sure you did not press the card in the wrong way around. Check the contacts on both the memory card and in the camera.
Check if the card is still working when placed in an external memory card reader, connected to the PC.
Look for the switch on the left side.
Before you put it in a camera it should be like the card on the left, the 64GB card. Switch up.
SOURCE: Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
SOURCE: memory card lock
So you're having problem in your memory card?
Try this:
1. Take out your memory card from the camera.
2. There's switch to lock and unlock on the memory card.
3. Just unlock it, and put back your memory card.
Hope this help! PM me if you have another questions.
SOURCE: Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
SOURCE: Memory Card locked: I changed the memory card in
if we are talking about an SD card ...see that in a side ..the card has a slide like button with 2 positions ...locked and unlocked... just unlock it cause it might have been locked when handling it...
