Question about Mitsubishi WS-65809 65" Rear Projection Television
Tv comes on but cant change channels - Mitsubishi WS-65809 65" Rear Projection Television
Posted by darwin on
TEXAS TV PARTS
    New Friend:
  • 22 Answers
Please replace main signal board,go to ebay and seach for TEXAS TV PARTS,or texasgreatdeals4you,for tv boards,lcd screens,plasma screens and more.
Posted on Jan 25, 2014
The channels on my ge 32gt720 tv keep changing by them self
Channel change button on the remote or on the side of the TV coule be stuck.
Jul 20, 2014 | GE 32GT720 32" TV
I have a 42 inch lcd tv. The tv will come on but the screen is blue Cant change channel or adjust volume. Any help would be greatly appreciated, thank you.
try to unplug it and a cable or sat box if used from power for a while to see if a reboot will help---also the fact you cannot change channel etc means the set experienced some kind of glitch.
Nov 04, 2012 | Sanyo 42 in. LCD TV
I got a remote control for my tv cant change channel
Did you attempt to program the remote with the tv? Is it a universal remote? If so, most remotes come with a list of codes to try with most tv's. Does the volume work? Can you type in a channel direct... pressing 5 for example? If those work but not the up/down channel, the remotes faulty. Or is it set to tv or cable?
Sep 28, 2010 | RCA Universal Remote Control
TV Stuck on 1 channel
We would be happy to help get that fixed right away. The first thing we want to ensure is that all connected equipment is on. We want to then check what type of cable was used to connect the TV to the receiver. If you are using a Coax Cable to connect the receiver to TV1, check the receiver's back panel for the output name. If your receiver has a "TV CH 3/4 out": Tune TV to channel 3 or channel 4, back if it is labeled "Home Distribution": Tune TV to channel 62 or 75. If using non-Coax (RCA, Component, or HDMI) to connect receiver to TV1, cycle through the inputs until picture appears; Most TVs have a "TV/Video", "Input", or "Source" button. If we are still not getting a picture then unplug receiver for 10 seconds then plug it back in, this will reset the receiver, then try cycling the inputs again.
We hope these steps resolve the issue. We want to thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jan 22, 2010 | Emerson EWF2004 20" TV
I cant get my Sony tv to change to channel 60 or 73 so i can watch Dish Network tv. Help Please!
It is probably a problem with your original setup if it has a built in digital TV tuner then you may have accidentally done a scan for channels. If you did not have an antenna attached to your TV then it would have come up with no results but would only let you go to one channel (whichever one you started on).
Dec 26, 2009 | DISH Network IR Remote Control
Cant change channels?
What is your antenna source? Cable or antenna? Try keying in a certain channel on your remote. see if you get that channel. Tv will not auto program if you do not have channel source coming in to antenna input.
Nov 03, 2009 | Sony FD Trinitron WEGA KV-20FV300 20" TV
Tv won't change channel
How is the TV connected? make sure all the channels are configured properly and the correct input is selected
Jul 03, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Mitsubishi WS-65809 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
