SOURCE: Error code in E studio 150
Hello! I did it and it worked perfectly.
I entered the SIM mode : CLear - Auto- Clear - Auto- then I pressed 14 -Start- Clear and then , the machine automatically warmed up and came to ready...Please, How can I be a copier Tech? I'm so eager to learn that. LET ME KNOW SO I CAN HELP OTHERS. THANKS SO MUCH...
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
SOURCE: How to determine what error codes for failure on Toshiba E-studio
Press "Clear+8" and u will see the error code.
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
SOURCE: ''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
