Question about Samsung N145-JP01US Netbook
Samsung 145 Net book was showing charging issues with battery. Now won't power up at all battery in and power cord in. Nothing at all but light is on the power cord no light at all on net book. Tried different plugs and different houses. Need new battery or cord?
Posted by Gabrielle Carlson on
Pranab
    New Friend:
    Problem Solver:
  • 12 Answers
Dear frnd,
Probably its battery problem but before change the battery you have confirm first its battery or Adopter problem. you need do first check the adopter to another laptop which has same charging pin . if its doesn't work with another laptop then you change the adopter but if the charger works with other laptop then you need to change your battery. try it..
Posted on Jan 15, 2014
5 Related Answers
Anonymous
  • 34 Answers
SOURCE: MY NET BOOK WILL NOT POWER UP, WHEN YOU SWITCH IT
that orange light generally means that your battery is no longer a battery. It is now extra weight supporting only a power connection. Do you have it plugged in while trying to power on?
if this happens when you have it plugged in, then you might have an issue with the AC adapter, often laptop AC adapters become weak near the plugs flex point and often crack, then fray, thus disrupting power flow.
Posted on Oct 08, 2009
Mohamed Omran
  • 2567 Answers
SOURCE: My Samsung p400 laptop won't power on. There are
1. Take the battery out of the laptop & try to turn on the laptop using power
adapter only. If the computer turns on, then the battery is defective & needs to be
replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the
power adapter using a voltmeter. Compare the voltmeter reading to the nominal value
written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re
-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try
swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Posted on Sep 18, 2010
Mohamed Omran
  • 2567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
6. The motherboard could be defective & needs to be replaced.
Testimonial: "thanks for the answers. "
Anonymous
  • 58 Answers
SOURCE: nc10 net book black screen
is there any indication that your computer is a doing anything? After switching on, does the Samsung Logo appear for a couple of seconds, the everything goes black?
You managed to post your problem on here; if you have access to another Computer with CD burner, can you download an ISO of Damned small Linux and burn that to USB stick (using UNETBOOTIN (they are both freee... Google them) With the computer OFF insert the USB stick. switch on and AS SOON as the Samsung logo comes up TAP the F2 key, Arrow left to BOOT menu and set computer to boot from the USB stick. IF this works - it means there is a problem with your Hard Drive... Please post back how you get on.
Brian.
Posted on Oct 05, 2010
N RYDINGS
  • 332 Answers
SOURCE: hello i need just the
goto the samsung web and click on support and down load it
Posted on Jan 25, 2011
Acer emachine s525.it will not power on,it refuses to charge.the charger lights up but nothing.I have tried using a different charger for another laptop it also shows that there's current coming...
The AC jack may be damaged due to pulling on the cord. Make sure the other cord/charger/transformer is the EXACT same power spec before plugging in, it may fry the laptops internal PSU.
Jan 15, 2013 | Computers & Internet
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
Samsung R480 Will not charge or turn on but indicator lights flash or stay on.
Swap out the ram one at a time testing to see if you can power up, making sure there is one in the memory slot at all times, if this works the piece in your hand is defective, no difference! the motherboard has major issues.
Jul 10, 2012 | Samsung R480 Notebook
R60 Wont Charge
What's the make and model of your laptop? Most times the flashing lights will tell what the issue is.
If the laptop will not boot up so you can use it then the things below applies.
Sounds like your power cord is bad. Or the DC Jack is not soldered on good. Just because the power cord is new does not mean it works. Some Power Cords have a little green light on the adapter to show that it is plugged into the wall and getting power, check yours.
Anything ever post to the screen when you hit the power button? Do the fans start up, the hard drive spins? If not, maybe your power cord has enough power to emit a light but not enough to start the fan or disk drive.
If it's not the power cord or dc jack, then you have a Memory or Video Card issue.
OK after reading your post a 2nd time I think your only issue is that the battery is not charging, correct? If that is true the things below applies:
Either the battery is bad or the power cord is bad. Just because they are new don't mean they work. See if the Adapter portion of the power cord has a green indicator light that comes on when you plug it to an outlet. If it does, and that light is not on the power cord has issues. Also I hope you did not buy one of those one size fits all power cords from the big box stores where the end has a bag of different interchangable parts until you find one that fits into the laptop. If so, buy a power cord off ebay that is made for your laptop.
The battery might be bad and not hold a charge. I have seen new batteries that did not work.
May 16, 2012 | Computers & Internet
Hi my Samsung R730 wont power up after shutting down when battery was low have tried pluging it in to mains and pressing power button but nothing works
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 13, 2012 | Computers & Internet
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
Mar 31, 2012 | Computers & Internet
My sony vaio won't turn on
Laptop won't start up
I'm inclined to think that your power cord is bad and you have drained your battery.
Mar 30, 2012 | Fujitsu Siemens Computers & Internet
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
Mar 30, 2012 | Computers & Internet
My samsung N150 power switch is not working
The Switch ON? Are you talking about the Power Button? If so it could be that your Power Cord is bad. Some models of the Power Cord has a light on it and some laptops light up somewhere when the power cord is plugged in and working.
You might have been working off your battery and if the power cord is bad it was not charging the battery and now nothing will work because the battery is completely drained.
If the power cord is good, you might have a Static Charge Buildup. Remove the power cord and the battery, then press and hold the power button for 30 seconds. After 30 seconds put the power cord back in (not the battery, leave it out) and press the power button. If it starts booting you had a Static Charge Buildup and can put the battery back in now.
If all fails, take an ink pen and stick it inside where the power cord goes. If it is not tight then the DC Power Jack is bad and need to be repaired. This will require a complete disassembly of your laptop.
Mar 23, 2012 | Samsung N150 (36725723009) Netbook
Samsung N145-JP01US Netbook Logo
94 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
