I have not been able to cancel/delete a print job. It advised me that the printer would not be able to print outside the margins before I said OK. Now I can not delete that print job. I have rebooted the computer and the printer.
To clear stuck print jobs in Vista the procedure is nearly the same:-Start Orb>Search box, type: cmd [enter]
When cmd appears above, right-click it and choose "run as Administrator".
At the cmd prompt that appears, do: net stop spooler [enter]
Now you can cancel your print job and then restart the spooler: net start spooler [enter]
Ok, now I am actually running Vista and I tried my own instructions which don't seem to work!
Try this instead.
Click the Orb
Click All Programs
Click Accesories
RIGHT click command prompt
Click run as Administrator
Click Continue if the User Account Control pops up
now you should get the cmd prompt as admin
Type net stop spooler[enter]
Goto the print queue (control panel > printers) or the icon next to the clock, bottom right. right click, open printers folder.
Delete the documents in the queue
Back to the open cmd prompt,
Type net start spooler[enter]
Does that clear it?
I do not have a resolution to the problem yet
I am runnng Vista. Please advise how to clear the spooler running Vista.
Thanks
I did find out how to get to the command prompt in Vista. I cleared it and restarted the spool as instructed. However, it did not clear up the problem. It occurred again with another file. I have unistalled the software and am reinstalling it.
I have done the instructions. However, I can not seem to cancel the pending document.
Please advise next steps
Thanks
I need instructions for Vista please.
When I type cmd in the the search box I do not see cmd appearing and thus am not able to right click and choose run as adminstrator. The last time this happened I gave up and unistalled and reinstalled the software for the 5610. This printer is the worst printer I have ever owned. This all happened tonight with an error message telling me halfway through a print job that the printer had the wrong cartridges. I simply need to know how to clear the spooler in Vista. Thanks
