Car is dead, key will not come out of the ignition and we can't get into the trunk (elec. button no lever) to replace the battery. we do not know the exact year of the ion but it is either 2005 or 2006.
how do we get
into the truck
or
get the key out of the ignition.
If you have a cigarette lighter or power port, usually you can power up the system by using a jumper battery attached a a probe. connect the negative part of the jumper to any good metal surface. make a tube out of cardboard and insert it into the port, then use a phillips head screwdriver attached to the positive cable and touch it to the center terminal of the port while pushing the trunk button in.Even though the cardboard should act as a shield, be careful not to touch anything but the center contact!!!
There a battery peg under the hood so you can jump it
