Tablets & eReaders Logo
A
Anonymous Posted on Jan 15, 2014
How hard reset aoc mg70sr-4 ?
shokr
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 17, 2014
shokr
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
641
Points
How do i hard reset my lg uk 410 tablet
Settings --> Resent menu 9.
Reset settings menu--> Master Reset options YES --> enter your 4 digit security code. The default code was 0000 unless you changed it. This will delete the phone entries. Security menu allows changing security code. You did backup anything you wanted to save, right? Note that customer service may remotely repair some phone problems.
http://www.hard-reset.com/lg-410g-hard-reset.html
1helpful
How can i fix my Asus tablet it keeps shutting off?
Warning:- Hard reset will Cost your data, remove the microSD card
Hard Reset the Tablet
1- Switch Off your Tablet
2- Press and hold Power and Volume down key (in some case it can be Volume up)
3- Android logo with exclamation mark will appear, select recovery mode
4- Select Wipe Data
5- Select Yes- delete all user data
Now Tablet will be free from pattern lock
Different Hard reset factory wipe methods for Android Tablet
2answers
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
My samsung galaxy tablet 4 how do i reset my prouduct
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
If you have access to the OS, you can also perform a hard reset in Settings.
2. Select Privacy.
Factory hard reset
shutdown the phone then entre recovery mode and use those commands ( wipe data / factory reset ) and ( wipe cache partition
Unlock a aoc tablet
You will need to do a factory reset:
How to unlock aoc breeze tablet pattern
i have to many pattern attempts, how I can reset hard , AOC tablet.
Top AOC Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an AOC Tablet and eReader Expert? Answer questions, earn points and help others
