Question about FUHU Nabi 2 Android 4.0 Tablet for Children and Adults
My nabi wont charge
Its been un charged for about 7 months till i finally found the charger now it wont charge at all even left it charging for about a week
Posted by marcy campos on
EasyPC123
    New Friend:
  • 36 Answers
It could be the charger or you may need a new battery.
Posted on Jan 15, 2014
We lost the charger for a few weeks when we found it now the nabi won't charge.
Try reseting it by holding down the power button (while unpluged,first) for 5-10 seconds. Then plug in charger.
Jan 08, 2015 | Nabi 2
My tablet wont charge or turn on please help
Check its charger. If the charger is faulty, it won't charge the battery. If it is found OK, replace the battery. It is bad.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 17, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
We got a RULU in 12/2013. It worked for 3 months and now can not charge i
Some tablet brands will not recognize certain charger brands or connections.
First, try all available connections-USB-wall inverter, and direct computer connection (making sure the computer is awake and logged in). Second, try restarting your tablet. Third, try gently wiggling the connections on both ends, to see if it recognizes a charge. Finally, leave it plugged in for a few hours, even if it says it isn't charging. You may have a trickle charge-to put it simply, the cord is not giving the device enough power to qualify as a charge, but there is power traveling through the cord. If the charge level goes up a little over that time span, you have a trickle.
If these don't work, just purchase a new charger. They're sold everywhere-Wal-Mart, Target, Best Buy, 7-Eleven, name a store and they probably sell USB charger cords.
I hope I helped.
Jul 08, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Report faulty goods
You will be pleased to hear this is easily fixed! Unfortunately, this is a common problem with the Nexus 7.
I have already posted the solution here: My Nexus asus will not turn on even though it be charged over night Had...
Jun 03, 2014 | Google Nexus 7
My tablet wont work at all
all I cant suggest if its still under warranty take it back to place of purchase,my flatmates boy had same problem the guy at the shop where it was brought from fix it in about 2minutes and no charge .
Jan 17, 2014 | Nextbook Premium 7 Capacitive Touch...
Tablet wont charge
mine did this too, but i left it plugged in and it finally started charging it
Jun 12, 2013 | Samsung Galaxy Tab Tablet PC
My google nexus 7 wont turn on
Sorry to hear/read this.
First, try get a new charger and plug your Google nexus 7. Suspect a dead battery with no charge left on it.
Otherwise, confirm your charger isn't just lighting up whereas it isn't delivering any charge current to your device.
Next to try if your ac charger is confirmed good is to attempt replacing the battery; at the store, have them insert a compatible/similar battery and then try power on your device.
NOTE:
New batteries at the point of purchase have some charge on them; sufficient to power on your device.
Device not power on, DON'T PURCHASE NEW BATTERY. Obviously, you don't have a power/battery problem.
Device power on, then you either have a battery that has failed or that your device's charging port needs to be serviced or repaired.
Please post update/feedback asap. Thanks
Oct 10, 2017 | ASUS Google Nexus 7 Tablet
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
FUHU Nabi 2 Android 4.0 Tablet for Children and Adults Logo
272 people viewed this question
Top FUHU Tablets & eReaders Experts
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Tom Chichester
Are you a FUHU Tablet and eReader Expert? Answer questions, earn points and help others
