Question about Vizio E322ar
Vizio e322-ar turns on, displays VIA logo, then turns itself back off.
We turned the tv off with remote, went back an hour later to turn it on and all it will do is display the VIA logo in the middle of the screen for a few seconds, then the screen goes black and the tv turns off. Even the logo backlight on the tv body itself turns off. Then that little logo light comes back on. We tried unplugging the tv and replugging it back in, we checked all the wires coming out of the back. Nothing is loose, nobody touched the tv during that time frame. Fresh batteries in the remote. Everything results in the same - the tv won't start up.
Posted by Michelle Willford on
  • mark in boise
    mark in boise Jan 25, 2014
    Ours died about the same time. I wonder if they broke these tvs with a system update. it is almost like it tries to boot but can't. I could be they "bricked" the TVs. Let's do a class action suit against Vizio! :) Seriously ... I will search for some technician reset codes. There must be a way to restart a system update.
  • Kristin Jan 29, 2014
    Just got my vizio with this problem fixed for free, out of warranty. Call tech support and tell them that your tv was stuck on the vizio logo. They will have you power cycle it, which won't work but just go with it anyway. Eventually they will say that the problem is a result of a failed system update and that you need a new mainboard and will have someone sent to fix it.
mark in boise
    New Friend:
Posted on Jan 25, 2014
  • BTM21
    BTM21 Jan 25, 2015
    My E322AR just died tonight! Less than two years old. When I unplug it than plug it back in the vizio logo lights up for a few seconds and then fades to black! R.I.P. I guess?
FireballXL55
    New Friend:
  • 59 Answers
Usually when a TV fails to turn on properly a lamp will flash a number of times which with the correct info guides you in the direction of the fault.
Posted on Jan 15, 2014
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
freetek
Steve Allison
  • 5569 Answers
SOURCE: Vizio VX32L No Display and Can't Power Off
Old messages and bcipollina is gonna get to read this resonse twice; sorry-
If it just fails to turn on or ignores the remote, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
BTW, from what I have read about Vizio, I think they are close relatives to iLo which was also sold by Wal-Mart.
Quality control anyone?
Posted on Oct 25, 2008
Anonymous
  • 13 Answers
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Posted on Jan 22, 2010
Anonymous
  • 13 Answers
SOURCE: The LCD screen is dark with no sound or picture when turned on.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Anonymous
SOURCE: We have a Vizio model # GV47LFHDTV10A. When we
For the cheap guy like me who will probably do more harm than good:
Also check for the F3 Fuse on that same main input board. It is located in the upper right corner. Hard wired fuses; very small. You will see F1-F4 (F4 is empty). You can solder a replacement fuse right over it. I would recommend piggybacking the fuse with a fuse you can replace. Will need the holder and a new fuse. 6 bucks.
Doesn't solve problem, but I can go another 2 1/2 years and the wife won't blame me for screwing up the TV in the first place.
Posted on Feb 14, 2010
My samsung tv wont get past the logo screen on startup. It will seem like it is going to but the recycles and starts all over.
On some models this reset may work, disconnect TV from outlet, press and hold the power button on the TV itself for about 30 seconds. Wait a minute, plug the set back in and press power button once.
Hope this helps cuz I don't know otherwise..but thought i'd share.
Dec 28, 2017 | Samsung Televison & Video
Hi I cannot get rid of the AV2 logo which sits in the top left corner of the screen when I'm viewing via my recorder. Thanks Miranda
Pick TV Remote Control and press Display button once, On-Screen display [AV2] will disappear.
Hope this will help.
Sep 07, 2011 | Sony KDL-32S3000 32 in. LCD Television
Vizio LCD TV Model L37HDTV10A - I have attached a Digital TV Antenna to the proper input, but once I open the on screen display go to the DTV input and attempt to access the TV setting to program the...
Sometimes it takes a while for the TV to go through this set up such as a half hour to an hour. Just be patient an make sure the antenna is set to air.
Jun 20, 2011 | Televison & Video
When I turn my LG BD270 on, the disp;ay keeps scrolling "Hello" and the TV screen flashes an LG logo screen. What could the problem be?
Is your LG unit new, or have you had it some time? If the later, it could be capacitor failure, which can cause all kinds of issues. I had an LG DVD HDD recorder which had a similar problem, except the LG logo didn't flash on screen. Does your unit have a hard disk? The prblem with mine was that the machine would not boot. Eventually, even th date display went, and it would not start. Replacing a bank of capapcitors solved he problem. I didn't have the equipment, but a repair engineer did it for £25in less than an hour.
May 27, 2011 | LG BD270 Blu-Ray Player
We went to turn our TV on and when it turns on the Philips logo usually appears before it turns on. It is frozen on the Philips logo screen. You can't turn it off. And it will not go to the TV. I'v...
The standby power supply resistors on the inverter board have changed values. You will replace resistors R1217, (820K 1/4 watt), R1218,(820K 1/4 watt) and R1219 (390K 1/4 watt). Please use the values just mentioned. Or you may have the inverter board replaced. Take this note to a TV repair Tech.Thanks for asking and show a few hands of support!
Mar 12, 2011 | Philips 42PFL3704D LCD TV
KDL-32M4000 sony tv screen went black suddenly,
We are having the same problem! Whats the solution!!!?!?!?!?!!!?
Oct 18, 2009 | Sony KV-36FS100 36" TV
Froze blue screen
software fault take to a mobile shop to reflash
May 28, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Samsung logo
How old is the set and what kind of TV is it? LCD,plasma, direct view?
C-Dog
Feb 12, 2008 | Televison & Video
Screen went black but i have sound
i was watching tv and in the middle of the show the screen went black, but there still was sound. i turned it off thinking it was the cable for that program and when i turned it back on several hours later it still had no picture all connections are good.
Jan 02, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Vizio E322ar Logo
958 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
