Question about Viking Professional Series VCBB36 Bottom Freezer Refrigerator
Change door swing
Need to change the door swing from left open to right open
Posted by Len Petty on
Paul G
    Scholar:
  • 161 Answers
Ok before you can do this you need to work out weather or not the fridge has provisions for it.
first have a look on the top of the fridge and see if there are screw holes with plugs in them.
if they do then check under the bottom skirt and see if they are there as we'll.
if there is then you are in luck and you can do it very easily .
make sure that all your goods are off the door first.
release the bolts on the top and bottom and change the brackets around to where they need to be .
with some fridges, you swap them around top to bottom, I'm not sure with this one but you will find out soon enough
you will need a small socket set, screw drivers ,a level and about two hours.
Posted on Jan 15, 2014
How do I switch the door opening to the other side? I would like to change the dryer door opening from the left side to the right side. By looking at the dryer it appears this is possible.
Hello, Frazer -
Without knowing the make and model of you clothes dryer, it is a challenge to provide you with the precise directions for changing the swing of your dryer door. With that being said, this YouTube video may prove helpful to you: https://www.youtube.com/watch?v=VW9183PsCLc .
How did I find the YouTube video? Using Google I entered the following search statement, with quotation marks, as indicated: "clothes dryer door swing" .
This web page with written directions may also prove helpful:
http://homeguides.sfgate.com/change-dryer-door-left-right-66754.html .
Best wishes.
Dec 17, 2017 | Dryers
Can i change the swing on my whirlpool front loading washer Model#wfw9640xwoo
No, the door only swings open from right to left. They made no provision for swapping hinge location on that model, which has recently been discontinued. Sorry.
Feb 17, 2015 | Whirlpool duet Washing Machines
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I always get confused as to the door swing direction and I need to replace one of the handle sets. Before I order I need know if it is a right or left hand door. Can you help?
Yes, Here's how. It's all about the hinges. Facing the door from the outside, if the hinges are on the left, and the door swings to the inside, it is a left hand opening door. If it swings in with the hinges on the right, it would be a right hand opening door.
Best regards, --W/D--
Jan 28, 2011 | Garden
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Switching door sides
some model you can, some you can't....if there are pre drilled holes with plastic plugs on the opposite side you can....you will need to purchase hinges and maybe handles.
Jul 24, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
How do I reverse the door to open r to l
You would need to refer to the user manual for that model. See IF it has the ability to change the door swing. If it does, it will tell you in the manual how to doit
Feb 24, 2009 | Speed Queen AES28AWF Electric Dryer
Washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
Dec 28, 2008 | LG Washing Machines
Viking Professional Series VCBB36 Bottom Freezer Refrigerator Logo
103 people viewed this question
Top Viking Refrigerators Experts
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
john h
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
