Question about Whirlpool GEW9250P Electric Dryer
My whirlpool dryer model number GEW9250PW runs but it will not heat up
5 Related Answers
Anonymous
  • 247 Answers
SOURCE: no heat
First port of call is thermal cutouts - little switches that monitor the temperature of the air going into the drum and cut the heat off before it sets your house on fire if something goes wrong and it all starts to get too hot.
Disconnect the power, then open the machine up. Look for the metal duct that directs the hot air into the drum (you'll recognise it by the funny-shaped blower bit at one end, and the collection of terminals sticking out of it at odd places about halfway along).
You'll find that some of those terminals are associated with flat coin or button like objects held tight against the surface of the duct (the number and exact appearance of these objects varies a little from amachine to machine). Look carefully at these, and you'll find that one or two of them have a little reset button in the middle of them. Check again that the power is off, then give each of these buttons a gentle prod. With a bit of luck, one of them will make a sharp clicking sound - you have just reset a tripped thermal cutout.
Check whether this has worked by running the machine. If it has, then you need to find out what made it overheat in the first place and stop it happening again. This usually just means giving all the filters and ducts a thorough clean to remove lint that's restricting the airflow.
If the thermal cutouts aren't to blame, then the next suspect is the heating element. Diagnosing this is a bit more involved, though still managable as a DIY job. Check the cutouts first, then come back if you need help checking the element.
A.
Posted on Feb 24, 2008
Anonymous
SOURCE: whirlpool dryer problem
dryer works but does not heat up
Posted on Aug 11, 2008
Anonymous
  • 32 Answers
SOURCE: No heat in dryer and can't find reset button
Probably is no reset button on/in the dryer. Go here for more info on no heat in the dryer: Dryer Repair Help
www.RepairClinic.com
Posted on Feb 05, 2009
Anonymous
  • 1122 Answers
SOURCE: Whirlpool dryer heat not working
DO YOU HAVE A METER? FIRST CHECK THE DOOR SWITCH,SECOND REMOVE THE BACK PANEL AND CHECK ALL FUSES AND THE HEATING ELEMENT,LET ME KNOW WHAT YOU FIND AND WE CAN GO FROM THERE-MIKE
Posted on Feb 26, 2009
Anonymous
  • 767 Answers
SOURCE: Whirlpool Cabrio dryer problem
Hello my name is Heath the problem is the heating element is probably burned out and will need replace.
Posted on Apr 08, 2010
What is capacity of my whirlpool duet ggw9250pw1? I don't see the answer identified. thank you
The Whirlpool Duet ggw9250pw1 looks like it has a 7.0 cu. ft. capacity. This is based on two different sources. The first has the GGW9250PW1 in a list of parts for 7.0 cu. ft. capacity Whirlpool dryer models. See http://www.appliancepartspros.com/search.aspx?model=whirlpool%20duet%207%200%20cu%20ft%20super%20capacity%20electric%20dryer .
Similarly, the related electric dryer, GEW9250PW1, is shown as having a 7.0 cu. ft. capacity at AJMadison.com: https://www.ajmadison.com/cgi-bin/ajmadison/GEW9250PW.html .
I hope this helps.
Nov 27, 2017 | Whirlpool Dryers
My whirlpool dryer GEW9250PW stopped drying suddenly. This lights come on and the control panel works but when you push start there is a click and the sensing light comes on and it will eventually count...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 12, 2011 | Whirlpool GEW9250 Electric Dryer
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
How do you reset the gew9250pw dryer
Start by unplugging the unit and letting it sit for at least 30 seconds.
Mar 17, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer Model No. GEW9250PW. Dryer frequently fails to completely dry sheets and bedding no matter which cycle is used.
It could be many things check your vent to make sure it is clear all the way out the house,take your lint screen out and scrubb it with a brush it my look clean but it isnt.
Nov 15, 2009 | Whirlpool GEW9250P Electric Dryer
Whirlpool Duet GEW9250PW-GR dryer with intermittent problem
You may have a bad key on the keypad. Does it respond if you push on the side of the key instead of the middle of the key?
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My dryer will run but won't heat
you either need a new heating element or limit switches
Nov 02, 2008 | Whirlpool LER8648P Electric Dryer
Replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer...
Hello jmylymok,
Welcome to Fizya,
You said, you replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer just beeps and doesn't work. When I tried the troubleshooting solutions, the error 6E comes up. What does this mean?
This sounds like the reason your bulb went out was more than just a bulb normally dying!
There is a short, or in that socked or the switch or it affected the the control panel too!!
This sounds like a hands on diagnoses job!
Let me know how it goes.
Huuum
Oct 08, 2008 | Dryers
Whirlpool GEW9250P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
jdthefixer
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
