SOURCE: Ethernet card problem
I have a Dell Inspiron and when it operates on batteries it automatically (by default) shuts down the wired network adapter when not in use. The solution may be to insure the network cable is plugged in before starting the laptop or to learn where in the power management utilities to turn on the wired network adapter -- I believe it can be done permanently at the cost of reducing battery operating time overall. It can probably also be done on a when needed basis. My Dell currently does not have windows on it and the operation on my machine may not be the same as on a Latitude. When this happened I used to get little balloon notices from a systool bar icon, however I also modified the default configuration to show my network devices in the systool bar when connected as well as when disconnected.
SOURCE: How do i use my built in wireless connection to connect to the internet,please.
funny what is virgin is it virginmobile ? cellphone ? you need usb cable to pc from cell. also its nto a router thats built in its a wireless card for 802.11g not for cellphone companies.
SOURCE: Ethernet adaptor and Local Area Connection 2 cable unplugged
Is that an external usb nic card? you can just directly connect it to the usb port.
SOURCE: Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
SOURCE: Dell Inspiron 2200 cant connect to internet
See device manager if you have driver installed for modem....
