Tablets & eReaders Logo
A
Anonymous Posted on Jan 15, 2014
Dell Latitude 10 ST2 tablet
The power won't turn on, battery is fully charged. When I press the power button the light comes on and immediately goes off. Table is only 2 months old.
5 Related Answers
Anonymous
  • 24 Answers
  • Posted on Apr 05, 2008
SOURCE: does not turn on under battery power
Battery may be faulty, perhaps you can swap with another user to rule this out. Do the battery charge level lights on the back of the battery show a full charge? (Press the rounded square button on the back of the battery itself and note whether the 3 green leds light up or not) Has the battery been calibrated? (You will need the "toaster" style or the DT533A charger to do this). I assume that your battery is secure and properly seated, but try taping it down from the back side just to be sure it is snug. Don't use duct tape, just regular scotch style tape or blue masking tape. Also try laying on your back to hold the unit upside down and power it up. Check the small metal fins that mesh with the battery. They are right above the right side of the windows cert of auth sticker when turned as you would to read it. They are NOT all the same length, do not push or pull them, but if one is bent you may try to straighten it VERY carefully with very small tools.
What happens if you unplug while up and running?
How does the power jack feel when you insert or remove it? any looseness may indicate your trouble. A good tech can repair your trouble. Are you sure that you are not under warranty? HP still sells extended warranty for these machines. My original warranty expired in Sept and I bought extended warranty for another year. I'm in central MO if you are close by at all I would meet up and swap a batt for a minute for you. Also, you may get a lil more usability with a car cord if the problem cannot be resolved at all.
Best of luck! I love my tc1100 and the older brother tc1000 as well. I have several of each.
Anonymous
  • Posted on Nov 23, 2009
SOURCE: Power port on le1600 does not charge batteries.
We contacted Motion about an issue with our docking station because our power & USB ports stopped working, or worked only intermittently. We were instructed to remove the front cover from the docking station to check the connection of the cables. We found that the cable had completely disconnected (it had evidently pulled loose from tilting the dock up and down). Once the cable was reattached, and the cover reassembled, viola! Success!
Steve Stewart
  • 84 Answers
  • Posted on Apr 10, 2010
SOURCE: Wont charge or keep a charge
First off, a google search will show you several companies out there that will replace the cells in your existing battery for around $70. Not bad. However, you mentioned that positioning of the plug can get it to work. The solder joints can become broken from the board, and the small plug in jack will get loose after a year or two of plugging in to it.
You can get a replacement plug at fry's electronics, or many online stores. If you need a service manual, or driver disk set, you can get them at mpcdrivers.com
Anonymous
  • 32 Answers
  • Posted on Jul 20, 2011
SOURCE: Why won't my tablet let me logout of facebook?
Go to settings, applications, then find Facebook, click it, and click Stop or Close. That'll take care of it!
Anonymous
  • Posted on Sep 17, 2011
SOURCE: My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
Brand new tablet will not turn on
Make sure it is fully charged. Hold power button down for about 10 seconds and wait if nothing comes up press power again for half a second. Still nothing? Then put it on charge, it should show that it is charging with a light of a picture on the screen. If there is no sign of charging, wait about 3 hours leave the charger connected and press the power button again for about a second and wait for it to turn on or for the picture to show it is charging appears on the screen, (make sure the charger is on and connected) . Press the power button again for another 5 seconds and wait. sometimes it takes a little while to turn on, especially if the battery is very flat. Other things to try are check the charger on another device e.g. another table or a phone if you can and try another charger on the tablet if they are compatible, (usually the same plug is o.k, check the voltage is the same. most chargers are USB 5v). It may need a more powerful charger than most small phones,. you can try plugging the USB cable into a car charger or USB 3.0 port on a computer. 2 amps is common for most tablets. Apple may be different, hard to be exact without knowing brand etc.
If all else fails see the retailer
1helpful
2answers
My tablet will not turn on after charging it all night. Can I change the battery?
press and hold the power button 10 sec ?
Press and hold both power and volume down buttons for 10 seconds, then release vol. down button while holding down power button for another 10 seconds, before releasing.
plug to pc and wait to be recognized?
take out the battery so that samsung fully discharge so this should help reset replug the battery.
2helpful
2answers
My tablet want come on what's wrong with it
I've had the same problem with my RCA 10 inch tablet. I have charged it, tried the hard reset, used different chargers and even different outlets, and held the power button on for 60+ seconds with NO RESULTS! My recommendation is to contact RCA, which is what I am doing, and request an immediate replacement if yours is still under the 1 year manufacturers warranty. If you look these tablets up, you will see (as I have found) that this is apparently a common problem with the tablets. Wish I had known that prior to purchasing!
2answers
Why will a samsung galaxy 2 tablet not charge?
first go to a mobile shop ask hif it it is the problem of battry or some hardware problem inside the tab and also check the charger weather it works or not
Dell tablet dont go pass the dell sign when i turn it on
Power on the system and immediately press the Power + Security (Ctrl-Alt-Del) buttons simultaneously for a
second. This will allow you to run a diag on the hardware. Do all the tests. If all passes, then you may need to reload the operating system.
I am unable to unlock my new Zeepad. It keeps turning off.
I think you should return to manufacturer , cause if the zeepad came that way it's their problem
Top Dell Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Josh Lake
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
