Question about Toshiba Satellite M45-S265 Notebook
Boot up problem
I had a problem that required a reinstall from the restore disk.  After formating and reinstalling the program I aquired a new problem when I boot up the computer.
Often, maybe 8 times out of ten the boot up screen will go to a much smaller screen than normal, sometimes the screen is black and sometimes the screen comes up correctly but does not open the desktop, it just freezes.  Then once in awhile the computer will boot up correctly and I can work with the programs until it freezes up at random times.
I have taken out some files and programs in hopes that it may begin acting correctly.  I have symantec antivirus which is working.  I have office 2003.
I have gone to toshiba to check my drivers and they have not corrected my problem.  I thought it may be a faulty bios, so I updated the bios and it said I didn't need to update or upgrade it.  So, I'm stuck.  Can anyone help me.
My email address is [email protected]
Posted by Almoir on
Louie Role
    Brigadier General:
  • 6,966 Answers
Initially, the problem seems to be video related which could either be the video card or the drivers. On the times that the PC freezes, it could also be video caused. But then again could also be memory related. What's interesting is that chances are that your PC shares the memory also with the video, so the memory now becomes the common denominator on both instances.
Perhaps, what you can try are:
1. Turn over your laptop powered off.  There should be a squarish panel at the bottom cover with a screw or two.  Removing this small panel/lid/cover would exposed the memory. Moving the 2 retaining clips sideways away from the memory would cause the memory to slightly pop out. You can now remove it.  Using a pencil erases, rub down hard on the little gold connector/tips of the memory on both sides. Using a dry toothbrush, you can also clean the slot where the memories are installed.  Do not put too much pressure since the pins bends easily. Re-insert and power up/boot your laptop.
2. Another thing you can try is to redo the Windows installation all over again. But this time use a Microsoft Windows installer and not the recovery CD. Allow Windows to install even if some drivers would be missing. Once it has completely installed itself, pop out the MS Windows CD and insert your Toshiba drivers cd. Manually install all your needed drivers. Start off with the display driver and move downwards the list in the Device Manager. Reboot, and observe for anything out of the ordinary.
Hope this be of some help/idea. Pls post back how things went or should you need further information.
Good luck and kind regards.
Posted on Oct 22, 2007
Operating system missing
Computers indicating missing operating systems have means to resolvement. First, ascertain that the hardware components are in place prior to restoring the missing programs. For example, ascertain that the computer has disk storage components. In situation that hardware devices are within device only has encountered an impact causing crashes or volatile data media would require replacement. For example, ascertain the brand of the computer from where hard disk storages are purchased from retail. Once acquiring new hardest also requires acquiring new operating system complementing the component reviving computers. Prior to visiting computer component retail facilities requires ascertaining that brand of computers also ascertaining the prior operating system from which determines reviving the remaining devices. For example, computers that once performed on windows XP requires acquiring similar versions from retail to recapture the remaining components at installations. Significant importance with replacing computer operating systems is reacquiring the entire users programs that become volatile as a result of reinstallations. For example, computers require antivirus programs as an alternate program least made available with new operating systems. Also computers require new programs that were within prior device that would have become compromised with the crash or replacement. While at the computer retail market, ascertain from computer experts about resource programs that makes an improvement also complementary with new installations.
Mar 12, 2011 | Computers & Internet
How can I format my c drive?
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to
cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
???????????????????? hope this helps
Feb 07, 2011 | Computers & Internet
Acer aspire 3624 wxci boot password lost. How to get the boot password.
The windows has to be reinstalled ( Formatting the Hard Disk with DATA LOSS) Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer.
To start the system recovery:
  1. Restart the netbook.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
  5. Select ' completely restore to factory defaults
Oct 24, 2010 | Acer Computers & Internet
How can i reboot or format my hp laptop?
If you have recovery cd with your HP laptop just recover, coz HP laptop has recovery file in your hard disk to to recover to factory default. if no use bootable os like XP, VISTA and WIN 7are bootable just setup your bios setting, go to boot and setup your cd rom as your first boot so that it will automatically boot to your OS on the cd. and follow the rest of the instruction to setup.
Oct 07, 2010 | Computers & Internet
Why wont my laptop fromat?
i would first attempt reinstalling windows with your system restore disk, but if you opt to format first the parameter you are missing is the drive letter, which would be C:\
Mar 22, 2010 | Gateway 450ROG Notebook
My system crashed. Won't reinstall windows
Do you need anything that is stored on the crashed hard drive? If so, you need to get an adapter for the drive and connect it to a desktop pc as the 'd:' disk. then copy any files you can access that you need saved.
Re-install the drive into the laptop, use "FDISK /MBR" from a floppy drive or a USB drive set up as a boot disk to re-partition it, and install the master boot record, and then boot the CDrom to install your operating system afresh.
The error message you are getting is caused by the 'restore' program trying to use the C: disk programs, and they are not there. I think you may have a bad hard drive, as usually the programs will be found.
You need to find out if the disk is really really bad or just needs to be re-formatted. Follow the above steps to determine if you need a new drive or not.
tom
Jan 18, 2010 | Computers & Internet
Forgot my password
just reinstall windows..without formatting..this will keep all your files and programs ...( some of the programs will have to be reinstalled to work with the new sys32 ) but in general will be just fine...if we are talking about user password and you are able to boot to the bios at least to boot the installing from the disk process...
Dec 12, 2009 | Dell Latitude L400 Notebook
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
Want to erase and restore my computer
If your computer has a restore disk on it, only your have to do is hit F10 after boot and select the restore options provided by the sytem. If not you need a Win CD to make that operation to format and reinstall everything again on your computer
Jan 23, 2009 | Compaq Presario 5000 PC Desktop
Thamks
Hello Dean
In Ideal scenarios your Restore Disks should work even if you have the Vista on the computer.
I hope you are using the right steps in order to perform that restore as you need to boot up using the disk 1.
Another step you can do is to Reinstall the XP using a disk(Which you may borrow from someone) after formating the harddrive, however you will have to reinstall all the software programs and the drivers as well.
Hope this helps.
Regards
Sammy
Jul 10, 2008 | Microsoft Windows XP Professional With...
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
