Question about Kodak EasyShare C330 Digital Camera
Lens error 12 & 22
I dropped my Kodak Easyshare C330 and now the lens will not move. I keep getting errors 12 and 22. I did have the problem with error 12 before and did what was suggested and tapped the bottom and it worked. Please any suggestions would be great. I use my camera to take family and child portraits. and absolutly can not do without it. I went and bought a samsang one tonight but if I am able to fix my Kodak that would be great.
Posted by Cheryle on
  • 6 more comments
  • lync71 Nov 14, 2007
    I dropped kodak easy share C330 this morning and am having the same exact problem - errors 12 and 22. Hitting the bottom as suggested is not working...
  • allium Nov 19, 2007
    I bought the camera about a year a go , i brougth it out to use and the lens would not come it would on a lens error 14 would appear on the screen then the camera would switch off. Its an easyshare kodak c330
  • mitsi2000 Nov 21, 2007
    My lens wouldnt come out. I tapped it and now its out but wont retract.
    Was saying lens error 12 &22, now says lens error 14.
    Thanks,
    Sue.
  • rdb2 Mar 19, 2008
    Same as other peoples problem Lens does not come out gives error 12 and or 22 when I turn it on.
    my E mail is [email protected]
  • abundis69 Apr 03, 2008
    i turn on the camera and appear lens error: 12 then the camera shut down
  • artmom2 Jul 08, 2008
    Same thing happens when I turn it on Lens error 12 and 22 and then it shuts down
  • inna1972 Sep 30, 2008
    error 12
  • Anonymous Jan 19, 2009
    my camera was dropped in the sand and i was able to take 4 to 5 pictures with it but now when ever i turn my camera on to "Auto" it says lens error 12 and when i try to take pictures or turn the camera off, it says lens error 22 so any suggestions or troubleshooting solutions would be great
    Thx!!!!!!!
primeline31
Our school uses this camera. It's reporting a lens error 12 and the lens does not extend. Bumping it did not work, nor does pulling the lens out with a fingernail.
One teacher said that another school had LUCK by installing a new battery pack. The old one might not hold enough power to fully boot up the camera, causing the lens error.
I have noticed that the battery does not hold a charge for any length of time. This will be our next approach.
Cameras that are dropped, banged or bumped are not covered by a warrantee, so beware.
Posted on May 06, 2008
  • rengarajshan Oct 07, 2010
    i was dropped my camera two days to go. error 12 will occured pls send me how to slove this problem pls help me.
    my mail id : [email protected]
Anonymous
You have to dismantle the lens assembly. The lens got misaligned so you just have to realign it. But it is a lot of work. Had the same issue and was able to fix it myself..
Posted on Feb 02, 2009
Anonymous
Go **** your selves
Posted on Apr 25, 2008
I Dropped my camera model c330 and the lens will not return. I get lens error codes 22 and 12 and the camera will shut down.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jan 02, 2011 | Kodak EasyShare C330 Digital Camera
My kodak c330 turns on thens says lens error 12, and the lens door will not open. what does this mean and how do i fix it?
Dec 24, 2010 | Kodak EasyShare C330 Digital Camera
The screen keeps saying lens error 14 then its says lens error 22
pls tap the bottom of camera and see if it works i mean tap hard it might come out or not it is stuck with dust and sand or something like that or the GEAR might be broken then i will suggest buy a new one dont waste time in replacements
consider FUJIFILM.com they are good in cameras
Pls rate me WELL !
Regards
Zohail
May 28, 2009 | Kodak EasyShare C330 Digital Camera
Kodak C330 [lens error 14]
Hi Jesse, thanks for coming to FixYa.
The problem your having is that sand and/or dirt gets in the lens mechanism of the camera. When the little cog inside gets sand in it, it prevents it from moving. It is what causes 95 percent of all lens errors. The other 5 are when the retaining pins get misaligned and don't go back in the holes. Mis aligned pins happen alot of times when you drop it with the lens extended, so let's go with the easy one first.
Take an air compressor (or borrow a friends) and put the nozzle up to the space in between the lens and and the camera. Blow it out real good. It may take a couple of tries, but it should free it up.
Let me know if that helped, and feel free to rate my answer.
Rob
Mar 04, 2009 | Kodak EasyShare C330 Digital Camera
Kodak Easy Share C330 lens error 14 and lens error 22
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 08, 2008 | Kodak EasyShare C743 Digital Camera
Lens won't come out,lens error 14,kodak c330
same thing happened on my camera. think it got dropped. lens only comes out part way. pull out with fingers and then lens works fine.
Nov 27, 2007 | Kodak EasyShare C330 Digital Camera
Lens Error 12
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 02, 2007 | Kodak EasyShare C330 Digital Camera
I bought two of these on clearance and gave one to my in-laws. She suspected that one of her kids may have dropped the camera or pushed in the lens. I don't remember which lens error number had shown up, but I dis-assembled the camera to find out what the deal was. If I remember correctly, there is a way to manually turn the gears to put he lens back out. I left the lens out and turned it on and it worked perfectly. Fair warning though. It is VERY IMPORTANT not to touch the contacts for the flash EVEN WITH THE BATTERIES OUT!!! God did it hurt like hell... unfortunately it is fairly easy to do and I must have accidentally done it about 4-5 times while messing with it..
Sep 05, 2007 | Kodak EasyShare C330 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
1,010 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
