Question about AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA
Orange light is on instead of green light on freezer what does this mean
Dado
    Master:
  • AEG Master
  • 509 Answers
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Posted on Jan 06, 2015
1 Related Answer
victorwod
Victor Nwachukwu
  • 157 Answers
SOURCE: orange light is on instead of green
no. the orange light is the temperature light and the green light is the mains light.
Posted on Apr 08, 2010
Why do both green light and orange light stay on all the time?
Without knowing much about Frigidaire , I would say at a guess that the green light would mean there is power on and the orange would be that the temperature isn't down to what you have selected yet. Most freezers have these 2 lights or a display showing the same. Check that the freezer hasn't frosted up and the food has frozen correctly. If you have a thermometer, most domestic freezers should run at around -18 degrees celcius. If its a larger type for long term storage, the freezer would normally run at around -20.
Apr 11, 2016 | Frigidaire Freezers
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
Dado
Sep 02, 2014 | Electrolux Freezers
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
We have an ancient Kenmore Chest freezer. I don't know what the orange, green & red lights mean. Also which is "ON" 0 or -
the light tell you if the door is closed properly or not . Close the door tightly and check the lights. Then open it and check them again this will tell you the positiopn of the door for each colour
Oct 06, 2010 | Kenmore Chest Freezer 16082
Orange light is on instead of green in the freezer does this mean anything?
Apr 06, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
Nova scotia chest freezer - does orange light indicate fast freeze??
I have a nova scotia chest freezer on the indecater it is 0 to 5 which is the coldest number 0 or 5
thank you
Sep 20, 2009 | Freezers
Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
Jun 24, 2008 | Freezers
Defrost light stays on
Try advancing the defrost timer manually.
Jan 16, 2008 | Freezers
AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA Logo
1,583 people viewed this question
Top AEG Freezers Experts
john h
Terry
Terry
David Emmel
David Emmel
Are you an AEG Freezer Expert? Answer questions, earn points and help others
