Durabrand 5.1 Surround Sound Computer Speakers Logo
Question about Durabrand 5.1 Surround Sound Computer Speakers
Home theater circuit diagram
Surround is not effect
1 Related Answer
Anonymous
SOURCE: i want the circuit diagram for the 5.1 surround
i want information about motherboard 5.1 audio ports functions with their colours
Posted on Oct 03, 2009
The selector button no longer works on unit or remote...AU...CD...Tuner ...etc. WHY???
If the selector button on the unit AND the corresponding button on remote has no effect, then the problem lies with the digital circuit responsible for changing inputs and not the Remote or the selector knob on unit.. I am assuming that the other functions do work.
That puppy needs to be repaired unless you can live with the input that it is stuck on. U might try unplugging the unit for a while and then replugging it. On some newer models this "reboots" the electronics and restores operation
CD will not play in surround. How do I set to have music play in surround?
Unless your CD's are DTS-encoded, you can only SIMULATE surround or employ Digital Sound Processing from stereo sources to create virtual sound spaces and effects. The manual describes it on page 13.
http://www.lg.com/us/tv-audio-video/home-theater-systems/LG-home-theater-system-LHT854.jsp
Like any spice, using sound modes is a matter of personal taste.
Check out the Knowledge Base.
http://lgknowledgebase.com/kb/index.php?CategoryID=29
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3130
Having just setup a SC-BT230 Home Theatre Sound System, the SURROUND and SOUND buttons on the remote have no effect, so we cannot change the sound modes
Sometimes these buttons only work for certain formats eg. a cd may not play with more than the front 2 speakers.
Also, when you press these buttons are you viewing the home cinema on your tv? It may require you to press the sound/surround button, navigate a menu to select the setting then press OK (this is how my Philips unit works)
Hope this helps.
1helpful
No surrond sound
TV's are not sources of multichannel audio. The best you'll get is stereo analog. Get the best TV-related audio from the same source the TV gets it - in this case the Cable Box.
11helpful
4answers
No surround sound through tv
May be you have to set the Pro-logic option soundfield, this will matrix a 5.1 surround sound effect, unless of course you are sending a Dolby Digital 5.1 audio signal from your TV broadcast into the Home theatre system, also have to check the TV audio output to send audio output to a Home theatre system in other than 2 channel stereo.
Top Durabrand Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
