Question about Epson Stylus Pro 9600 InkJet Printer
Epson stylus pro 9600 service req 10020 - Epson Stylus Pro 9600 InkJet Printer
4 Related Answers
SOURCE: Because of power fail during printing my printer
Did you remove and reinsert the cartridges? Perhaps, clean the contacts. This is a cartridge error.
Posted on Sep 02, 2010
Phil Barberg
  • 158 Answers
SOURCE: we have an EPSON STYLUS
The codes should be in the owners manual. Otherwise go to the web site in the support area. Type in the printer model then look for error codes support.
Posted on Mar 01, 2011
caroldon
  • 17130 Answers
SOURCE: maintenance req 0040 on my
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Posted on Aug 09, 2011
isaac santos
SOURCE: I am Eric, I have
SIMPLY CLEAN CLEAR RIBBON SENSOR BY PASSING CAR PRINT AND SEE IF THE SAME IS PLACED ON SITE WHERE IS THE SENSOR AND MAKE SURE THE RAIL CAR THAT IS NOT WITH DIRT runs ACCUMULATED THE CATCHING THE CAR I THINK THE NAME OF It ENCODER RIBBON
Posted on Feb 17, 2013
Service req 0001001C
SERVICE REQ - 0001001C - FS origin (Suction fan shutter home position) error
Jan 18, 2013 | Epson Stylus Pro 10600 InkJet Printer
Epson 4880 stylus pro service req. 10037
Hello Frank,
i have the same 10037 error code in my machine. On internet is says it is 00010037 Print Head thermistor error. I can not understand the problem and service employee could not solve.
I would really appreciate if you can tell me what was the reason of the problem in your machine how the problem is solved on your side?
Best Regards
Cagr
May 23, 2012 | Office Equipment & Supplies
I am Eric, I have this error message on my epson stylus pro 9600, SERVICE REQ. 00010004
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
00010004 CR Motor encoder check error
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
Jun 24, 2011 | Epson Stylus Pro 9600 InkJet Printer
We have an EPSON STYLUS PRO 9600. We have received the msessage MAINTENANCE REQ 0040. Can you help us, please? Thank you very much.
Mar 01, 2011 | Epson Stylus Pro 9800 InkJet Printer
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
Epson Stylus Pro 9600 vs Agfa Sherpa44
The Agfa Sherpa is not manufactured by Epson. Both Epson and Agfa buy and retag their printers from Mutoh.
I do not know if the 44 is the same as Epson 7600 or 9600, but it should fit the same cartridges.
If the printer does not accept the cartridges, that means that there is something different in the software stored in the Epson cartridge chip.
In this case you will be only able to use only Agfa or Mutoh Falcon cartridges.
Oct 27, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9600 InkJet Printer Logo
94 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
