Sanyo DS31590 31" TV Logo
A
Anonymous Posted on Jan 14, 2014
Remote code for rmt-u130 - Sanyo DS31590 31" TV
2answers
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
I have a Phillips Magnavox tv and need the codes for the Sanyo rmt-u130 remote I have lost my manual.
Sanyo remote have no set-up code to Magnavox. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
How do I program a SANYO RMT-U110 "Moonlight" to operate a Magnavox MDV 2100 dvd player?
Download manual
THIS IS THE MANUAL AND HOW TO PROGRAM YOUR REMOTE CONTROL. JUST CLICK ON THE LINK. THEN PRINT IT OR SAVE THE LINK FOR LATER.
I NEED THE MANUAL CODE FOR A SANYO RMT-U130 UNIVERSAL REMOTE FOR MY SAMSUNG TV
If you know the setup codes to check with your TV brand,
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you do not know the setup codes, and wish to know more about setup codes and setup proceedings to many brand remote controls, check this site. General setup codes to check with Samsung brand TVs are : 0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Sdvd codesanyo RMT-U130
Download the user manual to your remote control. Click here to download it. It has all details.
Need the codes for the remote sanyo RMT-U130
Universal remote codes for Zenith TV are: 0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
1helpful
WILL THE RMT V501A REMOTE WORK WITH SONY RDR VX55
Download the user manual for Sony RMT-V501A remote control, from nt. It will have all details, including setup codes. If there is setup code ofr your RDR VX555, you can synchronise the remote with your device. If there is no setup codes, it can't.
I do not know the steps to take to program my Sony Video (RMT-V306) remote to my Toshiba television.
To program your Sony RMT-V306 remote:
  1. Set TV_VIDEO switch to TV
  2. Turn on television to be programed
  3. Press & hold the I/O (Power) button
  4. Enter TV code (Toshiba = 07)
  5. Release I/O button
  6. Press I/O to turn off TV
If you have a different brand TV, you can get the code from Sony's e-support site here.
  • Remember, when changing batteries you will need to reprogram remote.
  • The RMT-V306 will not control all functions of your component.
  • Although not common, there may be some components the RMT-V306 cannot control.
2answers
Remote wont work i changed the batteries still wont work
first try to buy universal remote ,the TV remote sensor not recognize your remote.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
