Fossil FS2906 Wrist Watch Logo
A
Anonymous Posted on Jan 14, 2014
Size battery - Fossil FS2906 Wrist Watch
What size battery does it take for a Honora watch?
The size of the battery required for a Honora watch will depend on the specific model of the watch. However, most Honora watches use a standard watch battery known as a silver oxide battery or button cell battery. The most common size used in watches is the 1.55 volt button cell battery, which is also known as the SR626SW battery or the 377 battery.
To ensure that you purchase the correct battery for your Honora watch, it's always best to refer to the owner's manual or contact Honora's customer service for more information. Additionally, many jewelers or watch repair shops will have the necessary batteries on hand and can assist with battery replacement if needed.
1helpful
What size battery does my Emporio Armani AR-5331 take
The size of the battery that your Emporio Armani AR-5331 watch takes will depend on the specific model of the watch. Some common sizes for watch batteries include:
  • CR2032: A small, coin-shaped battery that is commonly used in small electronic devices such as watches and calculators.
  • CR2025: A slightly smaller version of the CR2032 battery, also commonly used in watches and small electronic devices.
  • CR2016: An even smaller version of the CR2032 battery, also commonly used in watches and small electronic devices.
It is best to refer to the user manual or contact the manufacturer to determine the correct size battery for your Emporio Armani AR-5331 watch. Using the wrong size battery can damage the watch or cause it to function improperly.
Battery size for kenneth Cole watch 4982
Renata brand battery size / number 377
Mexell brand battery size 626
1helpful
What type of battery fits my watch?
The battery size may be stamped on the back of the watch. Jewelry counters that sell batteries will determine the size and even change it for you. If you are a bit mechanical you can remove the back, mine has little screws but often it is one you pry open with a thin screw driver. You will then see the battery but don't move it until you make note which side is up. The size is stamped on it. Put the new battery in facing the way the old one was and close the cover.
Apr 27, 2015 • Watches
Replacement battery size for ar5303
it battery size 371/370
May 27, 2012 • Watches
1helpful
What size battery do i need for this watch ?
there are two batteries inside your watch one is for analog sr621 size of battery and the other one is for the digital cr2016 size of battery, i hope this will help you.
3answers
What size battery does this watch use?? I threw
the battery type should be written either on the inside or outside of the cover, or google up that model watch and find out online
1helpful
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
