Polaroid PMID1000B ARM Cortex-A8 1GHz Wireless Internet Tablet - 4GB I Logo
Question about Polaroid PMID1000B ARM Cortex-A8 1GHz Wireless Internet Tablet - 4GB I
Can't connect to Wi-Fi
NO signal for Wifi will not connect
Posted by Rhonda Hill on
2answers
Zte tablet model k88 wont connect to wifi
Weak wifi signal or defective tablet or router.
2helpful
My tablet will not connect to my internet
Can't connect to Internet through WiFi on Android Tablet/Phone. ... 4.Try to turn off/on Wi-Fi on the device. Turn off Wi-Fi first, [Settings]>>[Wi-Fi] >>[OFF]. Then turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[ON].
Can't connect to Internet through WiFi on Android Tablet/Phone - Asus
www.asus.com/UK/support/FAQ/1003867 https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=tablet%20will%20not%20connect%20to%20my%20internet
I can't get get my Google account to go threw keeps connection isn't strong enough which I have max strength wifi?
can you log into your wi fi router admin account ?
Can you try changing the channel from auto to say 3 channel numbers higher than the lowest channel number available . This is in case you have neighbors with wi fi that might be interfering with your wi fi signal .
I have purchased the iPad Air 2 and I have the Net Gear A6300 plus
The process is fairly simple.
  • Choose the setting app on your iPad (the one with the gear icon).
  • Choose Wi-Fi
  • Make sure the Wi-Fi setting slider is green (on).
  • click on your network name under "CHOOSE A NETWORK"
  • enter your password (if necessary) for that network
Your network information will be saved and you will never have to enter that information again.
If you don't see your network, check to see if your router is working, and move closer to your wireless router to complete the settings
If you don't receive a wifi signal where you use your iPad, you might reposition your router, or move your iPad closer, or get a wifi repeater (like an Apple Airport Express) to extend your signal.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
Cannot connect to WiFi for Google or Facebook. WiFi signal is red.
Enable the wifi first under the Settings WI-FI
Once it appears you select the net you want to connect inserting the password in the pop up message box
1helpful
2answers
Ok I asked the question three days ago why can I get on a free wifi connection with my phone but not my tablet
The free Wi Fi router may have run out of IP leases on its DHCP server just when you were trying to connect the tablet. If the leases are as an example say one week long then if lots of people connect to the free wi fi they get a lease for one week. So if the device comes back within the week it already has an IP address assigned to it and works. If a new device comes along it has to ask the DHCP server via the WI FI to assign it an IP address. If all available IP addresses are leased from the WI FI router the device will not get assigned an ip address. Would suggest trying to connect the Tablet on another Wi FI system to test it works.
I had this happen on my mobile phone when I was in Surfers Paradise in a Coffee shop and suspected the lease time on the WI FI router was too long for the amount of short term customers using the coffee shop. (the staff had no idea on why the Wi FI was not working so it would have been pointless to try and explain this concept to them and how to change the lease time on the dhcp server) Also there is a limit to the simultaneous number of users on a Wi Fi frequency on one access point . Unless the WI FI uses multiple WI FI access points.
2helpful
5answers
How do I connect to wi-fi?
To start you need to check you are entering the right password! The password is the one for the WiFi! Is it written on a card or on the router, it will be case sensitive!
1helpful
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
2answers
My tablet says I am not in range when I am and will not connect to my Wi-Fi
Delete your wifi on your Tablet and retry connection. It may be a hiccup in the system.
Open Questions:
Top Polaroid Tablets & eReaders Experts
 Mike M
Mike M
nexrad_chris
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
