Spectre 2004 Audi A6 - 3.0L V6 - Air Filter Logo
Question about Spectre 2004 Audi A6 - 3.0L V6 - Air Filter
My car is jerking when I push the gas pedal
And it only happens when I push the gas no matter what speed i m on I don't know if it's something serious or not
Posted by Vali on
Vincent G
  • 2,363 Answers
Check motor mounts and transmission mount
Also check the air tube (TOP AND BOTTOM) for hairline crack.
A worn motor mount can cause excessive vibration and damage the air inlet tube.
Posted on Jan 15, 2014
2answers
Why would new fan motor blow the air backwards
Lmfao at Ken, dude this is a single phase 120 vac motor. You can close your eyes and pick one there is no switching of wires to the motor. YOur hot can go to which ever and your neutral can go to which ever. DOES NOT MATTER :-P don’t reply unless you know blow horn. But just a heads up you can Reverse rotation very easy...
Ep9r 500 speed button won't work keeps flashing f
The water level sensor fell into the fan. Unplug the humidifier from the wall, stick your hand in between the fan blade and locate the sensor. It is a small black rectangular piece the size of a nickel but rectangular and 3 nickels thick. It also has a 2 inch stem sticking out of that clicks back and forth when you push it. Stick the sensor back into the sensor whole and the flashing f will go away and the humidifier will come on again.
I have an ecoquest flair that the fan won't run.
bad capacitor in the control head..if you run it at full speed, you may be able to run it hardwired(but it becomes a safety issue) may need it replaced..
Gas spits back if I pump too fast, and the check engine light is on --maybe a vent is clogged--Help!
GASOLINE in the air filter is a serious fuel injection problem....to be honest....I have never heard of such a problem...air goes through the filter into the cylinder where it mixes with gas....to have gas spit back into the air filter.......exhaust valve stuck? Maybe intake manifold is leaking? Gas from the tank goes straight into the cylinder via the fuel injection hose...how does it get into the air filter is really a problem. .
Model gch90703bxab
There could be other problems but check and see if your igniter is not burnt out. Ours did that and tried to ignite for two days and then I found I had to change the igniter.
Why it runs so loudly
Possibly, it may also need the bearings lubed. I use a 20 weight nondetergent motor oil, non detegent 10 weight can also be used.
Came home and unit was off and cannot turn back on. No response at all. Cleaned it and still nothing happens
Check to make sure the screen is pushed down in the back to activate the failsafe button. Sometimes the button can get finicky. Take off the screen and push it down with something. See if it does anything, if not, check the fuse and the plate, if it cracks, it's blow the fuse later.
No Medium Fan Speed
sounds like ur medium speed has gone out
Open Questions:
See all Spectre 2004 Audi A6 - 3.0L V6 - Air Filter Questions
Top Spectre Air Purifiers Experts
Jerry Kramer
Jerry Kramer
Lawrence Oravetz
Jesse Walters
Jesse Walters
Are you a Spectre Air Purifier Expert? Answer questions, earn points and help others
