I've seen this happen with power saving turned on. Look for your USB device having the setting enabled in device manager
Testimonial: "I looked into the manager but I found no properties that I could, change. The tabs at the top were as followed: general, driver, details. So my question: How do I turn off power saving?"
SOURCE: cordless keyboard
Dear Peachfuzz,
It seems that u have Multimedia KeyBoard what u have to do is just unistall the keyboard driver and restart the system then reinstall the keyboard driver it will solve u r problem.
Regards,
Bittu_8
SOURCE: Dynex Multimedia Keyboard not working
Check and install drivers for your multimedia keyboard which is came along with the Keyboard. Also check whether the USB drivers has been installed properly and check the status of the same.
Revert back for more assistance. Also give your valuabale feedback/rating on the same.
SOURCE: Why do I have to unplug and replug the USB every startup?
Because you have to set Digital Driver Signing to OFF EVERY-TIME you Boot your PC this is because the drivers are NOT "Official" Windows certified Drivers. You need to press F8 EVERY-TIME you boot your PC and go to the bottom of the list and select to turn OFF Digital Driver Signing before ANY drivers will work, if they are NOT certified.
SOURCE: I have a Gateway keyboard model number KU-0833. I
Hi lal1220,
I had the exact same problem with my keyboard (KU-0883). What you want to do is first go into your "Control Panel". From there under "Hardware and Sound", go to "View Devices and Printers". Right Click on your USB Keyboard and go to "Region and Language". Under the "Keyboard and Languages" tab click on "Change Keyboard". From the "General" Tab click on "Add". Scroll down to "English (Canada)" and expand it by hitting +. Uncheck "Canadian French" and "Canadian Multilingual Standard". Then press "OK". After which you press "Apply" and "OK". Give your computer a quick reboot and your good to go.
