Question about Onkyo Audio Players & Recorders
How to reset factory settings for onkyo tx-sv303pro without the remote
Rear speakers were turned to 00db n wont turn back up
Posted by john taylor on
  • 1 more comment
  • john taylor
    john taylor Jan 14, 2014
    Hi john taylor, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    trying to reset the factory settings without the remote...onkyo tx-sv303pro
  • john taylor
    john taylor Jan 24, 2014
    i have a universal remote that turned the rear speakers down and wont turn them back up and i wish to reset the unit to factory settings and i dont know how
  • Kelvin Irons
    Kelvin Irons Apr 24, 2016
    Look for a very small hole like in iPod use tooth pick or something wood press in and hold until it turns off .than it should reset when you turn it on .good luck its sometimes very hard to find .
Denis Perkovi?
    New Friend:
  • 21 Answers
To reset the AV receiver to factory default ,turn it on and, while holding down the (VIDEO 1/VCR) button, press the (STANDBY/ON) button "Clear" will appear on the display and the AV receiver will enter Standby mode. :)
Posted on Jan 26, 2014
2 Related Answers
anikanwins
SOURCE: How can I reset my Onkyo TX-SR601? Hard reset...
Hold Video 1 and Press the power button then turn it back on i had the same problem
Posted on Mar 11, 2010
Dennis McCollum
  • 137 Answers
SOURCE: how can I reset Onkyo receiver TX-SR602 without
press and hold vcr 1 button and then push power button, it will reset
Posted on Apr 14, 2010
Testimonial: "You are genius and excellent, thank you for your help!"
What are the advantages to doing a factory reset? I'am setting up tx in new place and need to start fresh. Does the tx reset?
Hello Arthur, The reset will take all of the settings back to factory default. This includes network settings and speaker settings. Thanks, FJD
Mar 27, 2016 | Onkyo TX-NR801 Receiver
How to program stations into memory of onkyo model TX-SV303PRO
If memory is not full, manually tune in the station that you wish to save. Then press Memory on the receiver on the left of the bank of buttons above the tuning buttons (the light will blink 8 seconds). Then press one of the Classified Memory presets (Class A - Class F); these are below and go to the right of the tuning buttons. The station will be stored in the lowest free memory space in that class. If the memory is full, you will see a message to that effect. If you wish to clear the memory, press and hold Memory and Mute (just to the right of the memory button).
The manual for the TX-SV303PRO is available from Onkyo support here: http://www.eu.onkyo.com/en/products/tx-sv303pro-98673.html?tab=Support . The downloads are on the right hand side of the page. The direct link to the English version of the manual is here: http://www.eu.onkyo.com/downloads/2/6/5/3/7/Manual_TX-SV303PRO_En.pdf . The information about storing channels is on page 12-13 (13-14 of the PDF).
I hope this helps.
May 31, 2014 | Audio Players & Recorders
Wire diagram for surround sound
http://static.fixya.com/Manuals/O/Onkyo/TX_DS595_5_1_61851C3AAA3EA98913A226B1F1FDDAD1.pdf there is the manual for your unit
May 08, 2011 | Onkyo TX-DS595 Receiver
Is it odd that my TX-SR606 Onkyo Receiver wont go into stand-by? It turns off but the standby light never lights.
try reset. push and hold vcr1 and then press power button while unit is on this will reset back to factory default
Apr 24, 2010 | Onkyo TX-SR606 Receiver
I have an Onkyo TX-SR507. I just hooked it up
Hello Katieandjona,
My first & second
guesses would be monitor & head-set modes...
(possibly Zone 2 activated)
ELSE...
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/ STANDBY] button (see page 93).
Manual... page 5
http://www.intl.onkyo.com/downloads/manuals/pdf/tx-sr507_577_manual_e.pdf
Hope this helps
Aug 26, 2017 | Onkyo Tx-sr507 A/V Receiver
MY REMOTE IS NOT WORKING FOR MY ONKYO TX-SV525,
Hello, I am sorry for your issue. Please go to replacementremotes.com and search txsv525. They do sell a replacement. If you email me at [email protected] and I will send you a copy of the manual. Thank you. Onkyo USA
Mar 14, 2017 | Onkyo TX-SV545 Receiver
Video thru Onkyo TX-RS606 is only black&white
are you using HDMI cables or component. First I would try unplugging the composite and component video cables while the receiver is off. Plug them back in and turn it back on. If that does'nt work try setting the receiver to factory default and redo the settings. You can find how to reset to default in your user manual.
Oct 24, 2008 | Onkyo TX-SR605 Receiver
Rear Speaker volume too low
Channel level output can be adjusted in the menu if you have the remote. Set the rear channel level volume higher and the fronts lower if need be, and then turn up the volume. Enjoy!
Jan 23, 2008 | Onkyo TX-SR500 Receiver
586 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
