I have gone to my network and sharing center and diagnosed the problem,it tells me to turn on wireless capability, and I have no idea to do it.
SOURCE: I have an HP Pavilion
First of all let's clarify that the wireless connection is between your laptop and the router, not between laptop and desktop. The router is the device that gives the data at the computers in order to view them as pictures e.t.c. The report from your laptop means that the wireless connection is not established. This is because either the distance between laptop and router is long, or someone has switched off the laptop's wi-fi. At the front panel or with a key combination (usually Fn+F2) the wireless connection can be manually switched on - off. Try to locate this switch and turn it to on position.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
SOURCE: cannot update drivers hp mini
Did they install correctly in device manger? HP downloads can be exe's and have to be run instead of updating. Does this make sense?
