Question about Ricoh IS Office Equipment & Supplies
I have problem with Ricoh Color Scanner IS760D.
Please help me asap. It is because my work are being piled a lot.
Posted by Teresa Wong on
4 Related Answers
Anonymous
  • 121 Answers
SOURCE: Ricoh IS760D
go into your properties by right clicking on the icon or goto my computer, look for your printer and right click to find property setttings.. you should be able to adjust your colors from one of the tabs that appear..d
Posted on Feb 22, 2008
ABRsvcs
  • 4234 Answers
SOURCE: Ricoh IS760D Functional Problem SC4020
Unfortunately, the message indicates that the internal startup tests have failed. If this unit is just past the warranty period, I would contact the manufacturer anyway and complain. No unit should fail that close to the period conclusion especially with little to no use. It is possible that a brown-out may have damaged the internal logic. Only a service tech for the company could tell you that. The blinking lights are an indication of the problem found. Report that to the company as well.
Good luck. Keep us posted.
Dan
Posted on Mar 18, 2008
Anonymous
  • 12 Answers
SOURCE: richo color scanner is760d don't have option auto feeder
This scanner can be controlled by PixEdit so you may scan any amount of sheets. Even easy continue scanning to one document when not enough space in the ADF for the hold stack
Posted on Aug 21, 2009
Stephen baynes
  • 394 Answers
SOURCE: I am trying to hook
Hi, I am steve, lets get you some help.
Your scanner only supports TWAIN and ISIS. Whilst you can use the scanner from Windows without any problem you can only control it from an application that supports TWAIN or ISIS.
As you have already discovered your application wants to use WIA - you cannot do this automatically. You may want to check whether your application supports either a TWAIN or an ISIS interface (I would expect it to). This is a long running issue with scanner devices.
You could use the Ricoh software and any TWAIN/ISIS enabled software to import the scans then upload the captured file into the application.
Sorry it can't be simpler than that.
Posted on Jan 17, 2011
Dan
Mar 18, 2008 | Ricoh IS760D Flatbed Scanner
Ricoh IS760D won't work with Windows 7 64-bit
Software (driver) can be found at driverupdate us.
Take a look... I hope this was helpful.
Cheers
Jun 27, 2012 | Ricoh IS760D Flatbed Scanner
Black line on right when scanning adf - have cleaned the machine dont know what else to do
If line appear in to your scanner pic no repair for that but is only when you print just clean the toner.
scanner Lents cant be change
Dec 17, 2010 | Ricoh IS760D Flatbed Scanner
Scannning too slowly
Increasing the default resolution setting, would slow the scanner down, and also increase file sizes dramatically
Feb 18, 2009 | Ricoh IS760D Flatbed Scanner
Ricoh aficio color 2003
related to the scanner
there is a white strip on the scanner glass , either that is dirty or the mirrors(optics) are dirty .
or scanner ipu board
Jan 15, 2009 | Office Equipment & Supplies
Richo color scanner is760d don't have option auto feeder
Dec 08, 2008 | Ricoh IS760D Flatbed Scanner
Ricoh IS760D
Feb 22, 2008 | Ricoh IS760D Flatbed Scanner
69 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
