Question about Radio Shack IndoorOutdoor Thermometer with Hygrometer
Radio shack 6300772 inproper display " raining and the display indicater slightly cloudy"
Posted by Pete Evans on
I have caller id service with my phone company; Why does my Radio Shack heavy duty wall phone with caller id display all rows of 8's in the caller id area?
It's radio shack... kidding, depending upon the age of it, the lcd black/grey display may have gone bad... from dropping or age or defect.
Feb 12, 2015 | Radio Shack Lands Phones
I have a Radio shack hand help police scanner, when I put the batteries in and turn it on, i just hear this low level static and some small clicking noise. The display finally came on for a few minutes but...
Take the scanner back to radio shack for an exchange. If you have had the radio too long then take the scanner back to radio shack and they will send it to their service center for repairs. Personnally I would upgrade to a digital scanner as things are getting ready to change nation wide. Most goverments will be upgrading to P25 digital to comply with the requirements of Homeland Security.
Jul 10, 2011 | Radio Shack Pro-95 Handheld Scanner
Can you replace the led for the faceplate Jenson phase linear ump401? Thank you in advance
The display is not an LED (Light Emitting Diode) it is a LCD (Liquid Crystal Display), behind the display is a tiny light or light bulbs that back light the display, yes they can be replaced, you can buy the bulbs at Radio Shack if the number can be crossed over, but most likely they are a Radio Shack # 7219 Micro Lamp
Nov 05, 2010 | Jensen Car Audio & Video
Very dim light on my pro 2052.
Display or backlight? If it's the backlight, you need to replace one solder-in bulb. Radio Shack part number 272-114 (5v, 25mA) will work. If it's the dispay you need to contact the Shack for a replacement.
Bill B
Feb 26, 2010 | Radio Shack Pro-2052 Scanner
My Radioshack Pro-64 scanner was left in the rain and wont turn on now. I took the cover off to see the internal motherboard; i guess you could call it that, and it is very clean, with very minimal trace...
Water and electronics just don't mix, so there's no telling how much damage was done. If you haven't already done so, remove the batteries, wipe the internal contacts with a dry cloth to remove any rust/corrosion, then try powering up with fresh batteries. If it doesn't power up after that, you can consider taking it to a local Radio Shack or repair shop for an estimate, but keep in mind that you can buy an exact replacement for about $70.
May 15, 2009 | Radio Shack Pro-94 Scanner
Radio Shack Pro 95 Display
Do a google search for GRE america store. They have parts for your radio. Their GRE 295 is the same (different in name only) as your pro 95. I think they are in Belmont shores here in the Los Angeles area.
Hope this helps.
Oct 23, 2008 | Radio Shack Pro-95 Handheld Scanner
I have a radio shack weather alert pro 82
Tilt the scanner in a different direction while looking at the display. Do you see anything on the display when you look at it from a different angle? Sometimes manufacturers don't put the LCD display in correctly, and because LCD's have a really small viewing angle it can result in not seeing what is displayed.
Oct 19, 2008 | Radio Shack Pro-82 Scanner
PRO2096 Blank again 3mos after "repair" seemed to work
Since the repair fixed it for 3 months and it appears to be doing the same thing, repeat the process but be sure to put anti-oxident solution (if Radio Shack does not have, try a real radio parts store in person or online) on the ends of the cable so the metal will not "rust" so soon.
Aug 04, 2008 | Radio Shack Pro-2096 Base Scanner
Cross talk
The easy way is to buy a radio surpressor. You can find them at Radio Shack, I think. Unless you live very close to a radio station you probably have a ground on your phone line. this can happen either inside or outside you business. Also if you are using a long mounting cord, 25' and up this can act as an antenna and cause radio pick up. I would try to detremine if your problem is on the phone company lines or inside your business.
the question said cross talk, are you hearing the other lines while you are on one line? If so you may have inproper wiring inside your building. Multiple phone lines must be on twisted wire. If two lines are parrell for any measurable distance they will bleed over to the other line.
Jan 29, 2008 | RCA 25414RE3 Corded Phone
Antenna not conecting to radio
I would take it to radio shack. Reason is that you can beat your self up over no signal and sit there and waste time on trying to think I fixed it ALMOST! In fact that is not the solution. Is your antenna catching as it is incerting into the femle connection...slightly snapping in or not? Is it falling out? Either way you may have radio shack test this part for you.
Dec 02, 2007 | Sirius Satellite Radio Receiver
Radio Shack IndoorOutdoor Thermometer with Hygrometer Logo
81 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
Harrie
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
