My scanner wouldn't scan because it said it was locked. Not so. clicked it back and forth, turned off computer, restarted and it's unlocked, the lights on, scanner bar scanning, but no scan that I can see. Tried both auto and regular - copy and scan. It worked fine until today. What can I do? [email protected]
SOURCE: Lock
Follow installation instruction given at installation Guide below:
(uninstall , re-install)
http://www.visioneer-europe.com/support/manuals/en.pdf
http://www.visioneer-europe.com/products/home/9020/default.asp
SOURCE: Problems scanning
Hmmm
If there is a second or main account on your computer that may be it.....
SOURCE: how do you unlock a visoneer scanner 5800
Ensure you are using the power supply
that was provided with the scanner.
The power through the strip may be
fluctuating and causing the problem.
Download and install the driver provided on the 5800 USB support website.
http://www.visioneer.com/support/flatbed/5800downloads.asp
SOURCE: 'Unlock the hardware lock' message
Does the scanning carriage move at all when the scanner is starting up? If not, then it might have stuck and needs to be moved back and forth a couple of times manually to loosen in, with the power not applied of course, and for that you would have to remove the glass most probably.
Also observe if the belt that moves it is properly attached to the carriage, placed over the motor gear and the support gear at the other end.
Of course the motor itself might have failed, or it's control electronics.
