Question about Samsung Galaxy Tab Tablet PC
Why my computer can't detect my galaxy tab - Samsung Galaxy Tab Tablet PC
Posted by zarita on
Tom Davies
    New Friend:
  • 15 Answers
There's several things that could be the cause here. I'm going to assume that you're plugging the tablet into the PCs USB port with the standard charging/data cable that came with your tablet.
Easy Solutions:
  1. You might have a bad cable. Try a different cable, if you have one.
  2. Your USB port might be bad - try plugging into a different USB port. If you're plugged into the front of the PC, try the ones on the back. Also try plugging a different device into the USB port that you were having trouble with - does the other device work in that port? If so, your USB port is OK.
  3. Go into the Settings app on your tablet. Select Storage and tap the menu (three dots in the upper right corner). Select USB Computer Connection from the menu. There will be two choices here: Media Device (MTP) and Camera (PTP). Try unchecking whatever one is checked and checking the other one. Unplug your tablet and plug it back into the PC.
More Challenging Solutions:
  1. You might not have the proper drivers for your PC to recognize your tablet. Samsung makes a software package for your PC to communicate with your PC called Kies. You can download Kies here: http://www.samsung.com/us/kies/ Download it and install it. Then plug your tablet into your PC and it should find it.
  2. There are other ways to transfer files between your PC and your tablet, some of them are really easy, some not so much. The easiest is the Dropbox app. Download the app from the Google Play store - it is free. Create a free account and sign in. Then on your PC go to www.dropbox.com and download their free Windows program. Install it and sign in with the same account info that you used on your tablet. This creates a shared space out on the Internet. Anything that you put in your dropbox folder will automatically get put in your dropbox folder on your PC. On your tablet you can look at what is in the dropbox folder and choose whether or not you want to copy it to your tablet. You can also upload files from your tablet to the dropbox folder (automatically putting them on your PC).
  3. Another way to transfer things between your tablet and your PC is the AirDroid app. You can download it from the Google Play store - it is free. When you use it on your tablet, it will give you a web address on your local WiFi. Go over to your PC and open a browser, go to that address and you can communicate directly with your tablet over WiFi. You can copy files, add and delete thigns, and all sorts of other functions. AirDroid is very useful.
Posted on Jan 14, 2014
5answers
How do i transfer photos from computer to samsung galaxy tab 4
Follow these steps:-
1. Using the USB cable, connect the Galaxy Tab to your computer.
transfer photos-h0svajhodyhiaq4t2lygvhba-5-0.jpg 2. Select the option Open Folder/Device to View Files, from the AutoPlay dialog box.
3. Locate the files where you want to copy to the Galaxy Tab.
Apart from this method, you can transfer photos via gamil.com, FB, and other social sites.
Thank you.
tip
How to put and play iTunes protected videos on Samsung Galaxy Tab
The Samsung Galaxy Tab is a line of upper mid-range Android-based tablet computers produced by Samsung. Big screen with HD screen resolution that makes the display to be brighter. So Samsung Galaxy Tablets are good choice for movie buffs to watch videos.
As advanced mobile devices, Samsung Galaxy Tab can support almost popular video formats like WMV9, WMV7, WMV8, H.264, MPEG4, DivX, H.263, VP8, etc.
However, you may find your Galaxy Tab can't play iTunes videos in .m4v format, even with some popular iOS devices like iPhones, iPod, iPad, etc. Samsung Galaxy Tab still can't be played well.
Why Samsung Galaxy Tab cannot play iTunes videos
iTunes movies / TV shows / music videos purchased or rented from iTunes Store are protected by DRM protection to prevent users playing in non-Apple devices like Samsung Galaxy Tab.
So If you want to put iTunes videos and play them on Samsung Galaxy Tab, you need to remove DRM from iTunes media and convert them to Galaxy Tab friendly format like MPEG4.
In this case, a suitable iTunes to Samsung Galaxy Tab Converter is needed. M4V Converter Plus for Win is an ideal DRM removal tool and iTunes converter for Samsung Galaxy Tab.
Besides Galaxy Tab, it can also support a lot of presets for iPod, iPad, iPhone, Sony PSP, Sony PS3, Apple TV, Gphone, Walkman, Blackberry, iRiver, Creative Zen, Xbox 360 and so on.
With the clear and simple user-interface, you can use M4V Converter For Win to convert your DRM protected iTunes M4V videos to Samsung Galaxy Tab quickly with high conversion quality.
8ac7457ca487455ce3b6/tumblr_inline_njlks7XJve1s1ugu5.jpg">
Guide to put and play iTunes protected videos on Samsung Galaxy Tab
  1. Add your iTunes video files
Download, install and run the iTunes to Samsung Galaxy Tab Converter - M4V Converter Plus for Win, click "Add Movies" or "Add Files" to import your iTunes video files. Batch conversion is supported so that you can add multiple files for conversion at one time.
2. Select the output profile and customize settings for Sasmung Galaxy Tab
Click "Convert to" format list, choose "Android Device" option and find " Samsung Galaxy Tab ".
bda673445622e29c884d/tumblr_inline_njll9ziUfT1s1ugu5.jpg">
Tips: If you have some special need and can't find the right one, you can easily set bitrate, codec, sample rate, etc to adjust parameters that affect video quality and file size for the video you prefer.
9b7185b93e77f3a54990/tumblr_inline_njllohUVr21s1ugu5.jpg">
3. Start the iTunes video files to Samsung Galaxy Tab conversion progress
After everything is done, hit the big "Convert" button to begin encoding M4V files to Samsung Galaxy Tab.
View more info at http://www.m4vconverterplus.com/ Convert Any iTunes M4V to MOV
2answers
How can I print from samsung 10.1 tablet to a canon mx320 printer
hi,
to get a page printed by your samsung galaxy tab you need to open the page you wanted to be printed and the select a printer your icon at the top of your screen then the tab wil automatically detect the printer will give you the print of the required page. Hope you get your problem fixed, If found any difficulties feel free to contact me anytime. Thanx
I tried to unroot my samsung galaxy tab 2 7.0 gt-p3100 and when i reboot the samsung logo won't disappear
Sound like a corrupt load.
Try to re-flash or upload a current version
The Galaxy is a current model and may be under warranty
Samsung galaxy tab 2 10.1 brought today and charging through computer keeps flashing a battery but then disappearing and making a disconnected sound from computer what do i do?
Samsung galaxy is a powerful device which require at least a 2A charger to charge it well. computer can only deliver 0.5A and thus is not enough power to charge your tablet. Connect it to the wall AC charger that come with the tablet and you'll be able to charge it just fine
How does the Samsung Galaxy Tab get firmware updates? I am unable to see any where on the screen menus. Thanks in advance!
Download and install Samsung Kies on your PC then connect the Tab via USB. Kies will detect the device and will automaticly notifies you on the screen if a new firmware update is available. Cheers.
6helpful
My galaxy tablet cannot detect our wifi connection. it always says disabled and scanning, obtaining IP address but will not connect. ive turn of/off the unit and entered the passkey several times but still...
Does the WiFi router have SSID? Did it ever connect to other WiFi Access Point before? If not some say to set the Tab on Static IP and configure the router to allow the Tab's MAC address. Hope it helps.
Samsung Galaxy Tab Tablet PC Logo
Top Samsung Tablets & eReaders Experts
Jayesh Panchal
Jayesh Panchal
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
