Air conditioner I have an eclipse d370 with esl control pad. It all went blank. I shut down the power supply and rebooted it. now I can not reset the temps. when I use the zones on the pad. the screen goes to blank. the only way I can go back to any screen is to close the cct breaker and start again. I cant switch it on or off except through the main menu. where can i get a complete service manual so I can work through it . I need more than a operators manual
Posted by SAM COPPOLA on
Paul G
    Scholar:
  • 161 Answers
Assuming your in Australia you should be able to download direct from their site but it sounds to me like the controller is stuffed
Posted on Jan 15, 2014
5 Related Answers
Therinnaiguy
Chandler Ede
  • 1420 Answers
SOURCE: Carrier air conditioner
Sounds like you either blew a transformer, have a bad circuit breaker or blew the main fuse in the outside disconnect. If the indoor unit is still blowing air (no matter what temperature) start looking at the power supply to the outdoor unit. From the circuit breaker, the power will go to a small box located within a few feet from the outside unit. This box will have either a lever on the side or you will be able to open the box and pull out the fuses. From this box the power goes to the condensor. The first thing you should do is to turn off the breaker to the outside unit. Flip it back on and if you have a call for cooling, after about 3 minutes the outdoor unit should start. If it does not, shut off power again to the unit by switching off the breaker, go outside and pull out the fuses in the disconnect box. Using a multi meter, check for continuity thru the fuses. If you have continuity, call your technician. If one or both fuses show no sign of continuity, replace the fuse(s). Make sure that the thermostat is working and sending a signal to the indoor air handler. You may be able to check this by turning the fan switch to "Fan" and see if the blower turns on. You may just have a bad thermostst. Caution should be used anytime you are near electrical components. If you do not have the skill-set required to test electrical equipment, leave it to a proffessional.
Posted on Sep 04, 2007
David Shaub
  • 2976 Answers
SOURCE: Will not turn on after a blackout
Check your breaker box. Also, check your receptacle. Some have a reset button at the receptacle. GFI Ground fault Interrupt receptacles are code for basements.
Posted on Jan 30, 2009
Thomas F. Schneider
  • 2715 Answers
SOURCE: air conditioner will trip breaker when trying to cycle back on
The compressor motor , once warm is grounding out due to wear and is going bad.Have the compressor replace while it is still clean is cheeper and easier that doing it after a burn out,which  will eventually happen,if the compressor is tripping the brreaker as I suspect..
Posted on May 10, 2009
Dennis Boxerman
  • 1305 Answers
SOURCE: reset air conditioner samsung aqv12msan
http://nodevice.com/user_manual/samsung/other4/aqv12msan.html
Go to this web site. It has a copy of a user manual. May get the answer to your question as to how to reset.
Hope this does it for you.
Posted on Dec 03, 2009
carl riggins
  • 70 Answers
SOURCE: carrier infinity a/c thermostat screens are blank - no power
There is a fuse in the control panel, and depending how they wired it may be a inline fuse. also there is a fuse in the airhandler also they both should be a 5 amp auto fuse.
Posted on Jul 18, 2010
Went to change thermostat on heat pump from conventional to digital. Did not shut power off. Could not get digital to work. Nothing, no heat, no air conditioning, and no fan. Put old thermostat back on,...
Here are the things our company would check 1st: Check to see if you have a control voltage fuse in the air handle section. If it is blown replace it and try again. If it blows again you may have wired the thermostat incorrectly. If there is no fuse than yes, you may have burnt out the transformer. Hope I helped.
Nov 08, 2013 | Ruud UBHC Air Conditioner
Compac pasario c500 on/off light just blinks when I power on computer screen stays blank?
Shut down, unplug, remove battery, plug in, reboot. If it reboots, open Control Panel, Power Options, Advanced power settings, Change Sleep and Hibernate to Never. Adjust the settings to your preference. Set the Screen Saver time. When your laptop is not in use shut it down and unplug, this will prolong life and a reboot everyday will reset your laptop.
Jan 17, 2013 | Computers & Internet
My control panel went blank and my ac quit. i tried to reset it and now it has an EE code and won't reset!
Reset the power to the unit by breaker if you havent reset it that way, just being redundantly safe.
If that does not do it, sounds like the boards bad. Its prettty much power in and ? comes out.
In other words say the fan needs to be on and nothing is coming out on the terminals to the fan then the boards bad, this is of course after insuring any limits and safetys are closed and bypassed to test 1st.
Sep 12, 2011 | Dometic Rooftop RV Air Conditioner
My power went out after the power came back on my air conditioner reads e1
E1 might be a stuck key on the keypad... they are sometimes flakey .. maybe water getting into the keypad ... at any rate the remote control usually still works .. eventually sometimes the key pad starts to work again (maybe when it dries out)
So, based on solutions from those other sites, I pulled off the front panel, turned it over and removed the 4 screws from the back of the control pad (not the six screws on the outer perimeter). I looked for a stuck button but did not find one. I just pushed all the buttons a few times in case one was stuck (as suggested on other sites) and that did it!
Hope helps.
Jun 11, 2011 | Haier ESA3109 WallWindow Air Conditioner
I get an error code e1 and have cleaned and replaced the filter. Runs for a couple minutes then shuts of with same message. Any ideas?
THIS SHOULD RESET IT
1 DISCONECT THE POWER PLUG FROM POWER SUPPLY 2 CLEAN FILTER 3 HOLD DOWN THE POWER ON/OF BUTON ON THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTILL IT EMITS A BEEP SOUND FOR APROX 5 SECONDS 4 DISCONECT POWER AND PLUG AGAIN
IF THAT DOES NOT WORK 1 DISCONECT UNIT 2 HOLD DOWN THE MODE KEY ON THE PAD OF THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTIL IT EMITS A BEEP SOUND APROX 3 SECONDS THE UNIT WILL START. 3 STOP THE UNITS OPERATION BY PRESING ON/OF 4 RESTART UNIT.
BEST OF LUCK
May 31, 2011 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
My central air conditioner was working fine but the power went out for about 2 hours and when it came back on, my air pump runs and the air conditioner fan is running but it blows warm air. What gives?
mcdevito75 here, Your A/C units control board is most likely transisterized or computer built, in which case when power went out so did the memory in your A/C control board. Simply shut down your A/C unit, re-start and make adjustments again for your comfort.
Aug 19, 2010 | Heating & Cooling
My air conditioner just shut down like it has no power but the outlet has power. Is there a reset button or something? It's a Comfort Aire Model RAD-151-B
Many window units now have a GFCI plug. If the power cord, where it plugs into the wall, is huge, it should have a reset button on the face or side of the plug.
If not, then a power fuse on the control panel has blown, or the control panel has died.
Aug 14, 2010 | Comfort-Aire RADS-151 Air Conditioner
Way to reboot ac system?
Most of the time, if the system is shut down by a fault code, you just shut the power off to the furnace and a/c for about 15 to 20 seconds and that usually resets them.
Jun 04, 2010 | Heating & Cooling
Fedders window ac was running control lights started going on and off ac went on and off then quit power supply is fine. reset does no good
assuming that you have a reset button on the power cord and after pushing the button you dont hear a beeping sound, there's the possibility that your cord is defective. Check it with a volt metter at the end of the terminals.
Sep 23, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
