Question about Apple iPad Mini
Other applications won't run says storage full
Loss of photos in Photo. FB won't run.
Posted by jesse baylon on
zoopmitty
    Novelist:
  • 207 Answers
You may want to check and make sure you didn't run out of space on your iPad. To do so connect your ipad to your computer using the usb cable and open up iTunes. Once connected and open look on the top right side of the itunes window and you should see a "ipad mini" tab. click on that and it should give you all sorts of info about your ipad mini. look on the bottom of that window and see how much/many "GB FREE" yours show. if your ipad mini is full its time to delete some of the apps you don't use. Also import photos to your computer to free up a lot of space on your iPad. In my experience photos, music, and movies take up a lot of space
Posted on Jan 18, 2014
I have a 7 in rca voyager tablet and until today it is perfect. I have always had a 16g sd card in with no problem. It shows in appa and storage but won't let me use it. I don't understand? Hello me..
When you say "anything", do you mean photos, videos and such, or are you trying to move apps to the SD? Most smartphones and tablets use SD only for storage of video, music, and photo data. Apps can't be loaded there and a few will allow app data there, but only if the app writers allowed for it. Apps are getting larger, but tablet and phone internal memory storage has been slow to keep up. As a result, users are faced with the ever-increasing likelihood that they will run out of storage for their apps and then must either upgrade to a newer device with more memory, or sacrifice some older apps. Its too bad we can't delete the bloatware apps that the manufacturer installs that we never use.
Sep 10, 2016 | Tablets & eReaders
I want to delete some videos from iCloud How can I do this on my iPad 2?
  1. Tap on Setting > iCloud > Storage. Then tap on Manage Storage.
  2. And then tap on This iPad.
  3. Under the Backup options, you will see Photo Library option, set the slider to OFF position.
  4. Tap on Turn off & Delete to delete all photos and videos from iCloud.
After deleting existing photos and videos, you can either set the Photo Library back to ON position and start backing up new photos to iCloud or keep it OFF and use Photo Stream. You can store up to 1,000 images on Photo Stream for free and download them to your computer. These images will remain in Photo Stream for 30 days, after which they will be deleted.
How to Fix Not Enough Storage on iCloud for Your iPhone iPad
Aug 17, 2016 | Apple iPad 2 Wifi 16GB
My tablet says insufficient storage but I have nothing downloaded what do I do
didnt specify type of unit --generic --open settings and look for what is stored in unit ---also if unit has email ,phone ,photo,notes capability they take up storage as well as internet open pages
Jul 17, 2016 | Tablets & eReaders
How do i get more storage for my ipad
I dont think the memory is expandable. but some people use the photo kit from apple and use it to store info on sd cards that connect to it. when I used it i did not care for it to much since it did not talk back and forth as i liked.
Jan 30, 2015 | Apple iPad Tablets & eReaders
How can I retrieve my pictures back that I had taken with my tablet camera ? For some odd reason my tablet keeps erasing me pictures .
You can have them back by Photo recovery process as your photos has been erased so the process would be this only. Also check your SD OR memory card may be storage space it not there for new addons. I suggest can suggest you services for picture recovery who can also guide you for the further precautions to be taken after retrieval. Digital Photo Recovery services to recover lost deleted or formatted...
Jan 30, 2015 | Tablets & eReaders
How to delete if internal memory card full
Hi
You can either download photo, data files to a SD card, another device (computer) or simply delete unwanted data by using the file brower. Locate, the unwanted files in storage, camera, or certain apps folders, & delete files. Don't delete any file in system folder. Hope this helps. Regards Bob from OZ
Jul 27, 2014 | tmax White 8GB 9" Android 4.2 1.6 GHz,...
How do I enlarge a photo on my i pad? I pinched swiped and no luck
make sure photo is first stored in "photos" on ipad, if its in an email or online site, sometimes you cant adjust, press photo for 3 secs first, save to camera roll, and then access photo from camera roll
May 07, 2014 | Apple iPad 2 Wifi 16GB
On my ipad I can not send pictures though email.How can I mix my promble
You can add photos to your emails on an IPad. If you have your email complete, just touch your home button to leave mail. Your email will still be there. Now, go,to your photos. Find the photo you want to attach. Tap it. At the bottom left, it should say "Copy". Tap "Copy". Now, go back to your mail message. Tap the body of the message. A list of options should appear. Tap "Paste". The photo you copied should now be pasted in your email message. If you want to attach a PDF, save the PDF in you Library in your iBooks first. Tap that PDF in your Library and a window will pop up with options. Tap "email" and a new email will appear with the PDF already imbedded as an attachment.
Nov 20, 2013 | Apple iPad Tablets & eReaders
How to delete photos from the Ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to delete the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to delete from the iPad under the Sync Photos from heading.
5.If you want to delete all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
Done.
If it can't work, you can refer to the article about Delete photos from iPad.
Good Luck!
Jun 25, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Open Questions:
See all Apple iPad Mini Questions
Apple iPad Mini Logo
116 people viewed this question
Top Apple Tablets & eReaders Experts
gaucherre
Shaukat Bhutto
Shaukat Bhutto
Nicola Conroy
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
