Question about Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WD 65737 black screen
I've tried unplugging and resetting but the screen is still black and doesn't respond to any buttons on the front panel or remote. Bulb is about a year old. Leading up to this the tv would occasionally just turn its self off. Unplugging worked a couple of times and now nothing and shuts off after a few mins.
myles harrison
    New Friend:
    Problem Solver:
  • 5 Answers
Sounds like the back light has gone mate. Unfortunately this usually makes the tv obsolete
Posted on Dec 22, 2017
5 Related Answers
JackAld
SOURCE: green power on light flickers
I can help if anyone with this problem lives in Anaheim CA.
Posted on Jan 19, 2008
Anonymous
  • 184 Answers
SOURCE: mitsubishi wd-62825 dlp
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Posted on Feb 14, 2009
Anonymous
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
Anonymous
  • 556 Answers
SOURCE: My Mitsubishi wd-52628 TV does not respond to any
Try to reinitialize the set , with the remote press menu 1 2 3 enter.
Posted on Nov 01, 2009
Anonymous
SOURCE: problems with mitsubishi WD 65737
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Posted on Oct 03, 2010
Panasonic PT-50LC13 50 in. Rear Projection HDTV Does anyone know how to reset the timer when the picture doesn't come on (black screen)?
Turn on the television after the new DLP bulb and housing are inserted into the chassis.
  • 2 Move close enough to the set to reach it easily. Hold the "VOL" button on the front of the television, while holding the "SPLIT" button down on the remote. Do this for 5 seconds. Note that some models require holding the "PIP" button on the remote in lieu of the "SPLIT" key. Verify which model is relevant prior to beginning the process.
  • 3 Verify that the reset took by waiting for a message to appear on-screen indicating a successful reset. Additionally, the "LAMP" indicator on the front of the television will go out.
  • Oct 16, 2011 | Panasonic PT-50LC13 50" Rear Projection...
    Samsung R4266w turns off automatically. I've
    Rest the lamp hour meter
    • 1 Press menu on the DLP's remote.
    • 2 Scroll down the list to "Timer."
    • 3 Press "Enter" on the remote, then "Reset." Press "OK" to complete the process, and "MENU" to exit the menu.
    Service Level Reset
    • 1 Turn off the DLP with the remote.
    • 2 Press a pre-determined button sequence on the remote control to access the factory reset option. These sequences are found in the owner's manuals of the various DLP televisions, or in the "Support" sections of the manufacturers' websites. Scroll to the "RESET" option on the menu to reset the bulb timer.
    • 3 Press a factory-determined combination of buttons on the remote and front panel of the individual DLP display to reset the bulb timer without entering a menu.
    Aug 14, 2011 | Samsung Televison & Video
    I got a shock (static, it's winter here) and then the source menu started flashing on the screen and continues to do so. None of the buttons are working now (on the unit, or the remote) and I'm unable to...
    I would suggest you pull the AC plug overnight to see if this will reset it. There are components that may take hours to discharge. If this doesn't help, you may have killed the IR receiver (or the cicuit that follows it) although it should happen on any newer consumer electronics that is properly designed and tested.
    Both the set-top buttons and the remote eventually act on the same control circuit and if that has failed, it will not respond to remote or local control.
    Apr 24, 2011 | Akai PDP42Z5TA 42 in. Plasma Television
    62HM15 Toshiba DLP TV won't respond to remote or control panel
    Blinking is a trouble code. Try unpluging for a longer time then hold power button in when pluging back in to try and reset.
    Mar 15, 2010 | Toshiba 62HM15 62" Television
    Toshiba 36a43 tv has the demonstration screen running constantly over regular programming. Can't get it to shut off, remote will not respond & there is no reset button. Help please?
    The problem is most likely the switches on the front panel. If the manual buttons are constantly shorting out, then the TV will try to respond to those buttons, and not the remote. Manual buttons almost always override a remote. Check the front panel for shorts, or if the buttons are constantly depressed.
    Dec 13, 2009 | Toshiba 36A43 36" TV
    Mitsubishi WD-62627 62" DLP TV
    Try this:
    1) turn on the TV
    2) from the remote control press MENU 2,4,7,0 then ENTER
    3) tv will state on screen that it is INITIALIZING
    4) when done press the front reset button.
    5) should be good to go!
    Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
    Power and front control box not working
    Try a har reset, by unplugging the Tv for about 5 minutes then plug it back in and see if the remote functions are restored..
    Bill
    Nov 02, 2008 | Akai PT5492S 54" Rear Projection...
    Tv wont respond because device menu is changing through each device
    I had a similar problem: my WS-55511 would not respond to the remote and the front control buttons (with the exception of Power) cycled through the Device Menu. I solved this problem by disconnecting the front panel. Here's how to do it: 0. Unplug the TV
    1. Remove the speaker grill from the front by pulling forward: there are no screws. 2. Disconnect the two cables that are exposed after the grill is removed. 3. Plug the TV back in, wait for 5 minutes to reset. 4. Try using the remote.  Hope this helps!
    Oct 06, 2008 | Mitsubishi WS-55511 55" Rear Projection...
    LOCKED HITACHI TV
    need model and chassis number and I' may help you email me
    Mar 20, 2008 | Hitachi C21RF39 21" TV
    Parental Lock
    Try unplugging the tv for a few minutes. This reset the front panel lock on my JVC tv. I got it from the manual, which I found at the JVC site by Googling the specific model of the tv along with JVC and manual. I found the manual right away.
    Jan 12, 2008 | Televison & Video
    Mitsubishi WD-73827 73" HDTV DLP TV Logo
    466 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Todd Hill
    Todd Hill
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
