Question about Kenmore 44042 Front Load Washer
No error messages, just loud groaning sound
No error message - just buzzes but still spins
2 Related Answers
caroldon
  • 17130 Answers
SOURCE: kenmore 80 series washer won't spin just makes a loud buzzing noise.
Possible that the motor is not moving , could be a faulty capacitor to the motor. Also check for the free movement of the agitator, if the shaft is tight then it can cause a drag on the motor.
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jun 29, 2012
digitdoug523
Douglas Wade
  • 15 Answers
It sounds as if the tub may be lodged in off balance mode causing alarm to buzz , check tub for centering as well as should be a paddle or hard wire near tub to trip off balance switch possibly not releasing,check for free movement and continuity that would most likely be no continuity not touching tub.
Posted on Jan 31, 2015
I get a message "Fuser open heat error. I turned
The main power supply board in short we call it (SMPS) the error you got is quite common that the main power is not getting in to the transformer in the correct voltage. Normally is to replace the SMPS and the fuser as well.
For more Technical test on the SMPS 1st of all we will test the fuse on the SMPS which is located at the bottom right hand corner. using a multi-tester, 2nd will be the capacitor and 3rd which is the last will be the big and small transformer with power on. note the last test is dangeroures unless you are a electrician experts.
Best of luck!
Sep 06, 2011 | Samsung ML-2510 Laser Printer
When I press the start button on my LG front loader I get a buzzing sound & it won't start. No error message and lint is all clean??
If it makes a loud grrrrrrr sound then the motor is bad Or a sock or something may have got past the lint filter and is keeping the blower wheel from turning.
Spin the drum a few times both directions by hand and see if it turns freely.
Jan 15, 2010 | LG Dryers
The microwave is making a buzzing noise and not heating
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number and date from the tag in or on the unit.
Also please let us know which of the above yours' noise sounds more like.
Nov 29, 2009 | Goldstar Microwave Ovens
Microwave turns on but it makes strange noises and does not cook anything. After a little while I get an error message that says something like cooking sensor has timed out
So we can help you, please post a NEW question, and please include your full model number from the tag in or on the unit, as well as the answers to these questions:
When you try to microwave are the inside light, internal cooling fan and turntable all working?
Is there any unusual noise or is it louder or quieter than normal?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Oct 11, 2009 | GE Microwave Ovens
My computers hard drive makes a Buzzing noise
I would suggest you back up all your data as the hard drive appears to be failing. i presume you are certain it is coming from the hard drive and not a fan ?
Feb 21, 2009 | HP Computers & Internet
Kenmore HE2 Elite is making groaning noises and then error messages 5D and/or F
did you clean pump out by removing acess port on front end of pump? also you can ckd pump impeller by removing screws around pump body impeller will free wheel but should have some resistance to turning by hand if no water in tub reinstall pump put in drain spin to see if drum will spin if it does forget main motor ..motor is most reliable par on those washers
Aug 06, 2008 | Kenmore Elite 45986 Front Load Washer
Nd error essage
nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Loud groaning noise when copier is turned on.
sounds to me like the laser unit is going bad. common problem on this model.
razors
Nov 28, 2007 | Copystar CS-1510 Copier
Washing machine - not spinning, loud buzz
Sounds like your machine is not receiving any water. It could be that your tap (fawcet) is turned off, or there's a kink in the hose.
Nov 26, 2007 | Washing Machines
Kenmore 44042 Front Load Washer Logo
Michael Thomas
Michael Thomas
Paul Carew
Lawrence Oravetz
