I need a manual for my Fujitsu air conditioner
I have trouble staring up the cooling system, i do not knew which buttons to press
Posted by joan macrae on
Paul G
    Scholar:
  • 161 Answers
Google the model of your unit
Fujitsu have all their manuals on their site
Www Fujitsu dot com
Posted on Jan 15, 2014
3 Related Answers
Anonymous
SOURCE: Fujitsu wall mounted air conditioner.
Is it a split system? I had the same problem with my split system and and it was because the condenser line was mounted wrong. The line was mounted so the water had to go uphill and it was causing the condensation to leak through the front of the unit.
Posted on Aug 14, 2007
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: We have a fujitsu reverse
Check if the remote control if still good, using the camera of your cellphone point remote control to the cellphone camera and press the "on" button of your remote and you can see the light emitting from your remote control transmitter. If the lights emits that means your remote control is good, if not means the remote control is defective.If the remote control still good try to press the RST or RESET button on your remote control and try. If wont works it means that the reciever board in the indoor unit is defective.
Posted on Aug 29, 2008
Anonymous
  • 10 Answers
SOURCE: I have a model AR DL10 remote for a Fujitsu air
After changing the batteries you have to depress the RST button and if the remote has the abcd slide switch ensure it is set to A.
Posted on Jul 15, 2010
Testimonial: "THANKS"
FUJITSU ISN'T COOLING CORRECTLY
Most of the time with those units... you have a refrigerant leak...
They also usually have led's that blink to give you a code as to what is wrong...
the blinking can be on the indoor unit or on the circuit board of the outdoor unit...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Feb 01, 2011 | Fujitsu Heating & Cooling
Doesnt seem to get cold enough
heatman101
Dec 12, 2010 | Fujitsu Heating & Cooling
We bought a house with Fujitsu Air-conditioners we have no instruction manual on how to use the remote. Im trying to set it to go off after an hour or so. Model No.INDOOR UNIT is, AST12RSJCW Serial No is...
Switch on by pressing ON/OFF. Press mode button to cool position. for cool and keep required temp by clicking
Same procedure for Heat. For heat keep +29 and for cool 25 to 22 degree. Press fan for High, Med,Low. If you keep mode in Auto cool and the fan speed will be low and you can't change fan speed.
Please visit Fujitsu website for further details. Hope my msg is helpful?
Dec 09, 2010 | Fujitsu Heating & Cooling
Flashing green light persist even after the filters are cleaned and properly reinstalled. no air conditioning function
There are many things that can cause your air conditioner not to cool…
heatman101
Aug 30, 2010 | Fujitsu 24C1 Air Conditioner
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
How do I change from heat to cool on the remote for my Air-conditioner.
press snow flake or sun. press flames or cool wind. press heat or cool. press system button several times.
Oct 20, 2009 | Fujitsu 18C1 Air Conditioner
Hi I have a Fujitsu Split system. As of recently it has started to mysteriously started to flick over from heating to cooling on its own. It is a 2.5KW unit and heats rather well. ALl of a sudden you hear...
Yes i can! The mode of operation (MASTER CONTROL)has been set to AUTO instead of HEAT. Easy mistake and very simple to fix. Press the MASTER CONTROL button until HEAT is display on the LCD.
I hope that this helps
I take the time to answer you questions so please rate me
Thankyou
Mat
Jul 13, 2009 | Fujitsu 18R1 Air Conditioner
We have a fujitsu reverse cycle air conditioner. Last night when we went to turn it off with the remote it did not respond. We needed to turn it off at the switch outside the house. We replaced the...
Aug 20, 2008 | Fujitsu Heating & Cooling
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
