Have you done the testing at the starter wiring your not receiving hot to the solenoid circuit on the starter when the key is turned over? Place a test light on the connector for solenoid hot and have some one turn the key if it lights check for constant voltage on the large wire connection from the battery to the starter. If that's all working your starter is bad.
Yep....starter relay or ignition switch. Loose or corroded cables.
Anything from the ignition switch, connections, wiring ,fuses and relays up to the starter connection . Corrosion, loose connections or broken wiring or cables can cause voltage drop or no voltage at all .
SOURCE: Low Bean Lights Inoperative on 1997 Acura TL
If your car is running daytime running light system .. there is a DTR relay that goes defective and needs replacing ... I had the identical problem that was fixed with this replacement. The DTR relay is behind the glovebox.
SOURCE: 99 Acura TL dies when I try to start
I have helped many Honda/Acura owners on this issue. Many mechanics will replace many parts prior to solving this problem, which then creates unnecessary repairs and spending. So here is my diagnosis: Notice if your speedometer drops to zero when your engine dies while driving. If this happens its your ignition switch failing. Ignition switches in Honda/Acura vehicles years 97-02 encounter faulty or shorted internal contacts. This causes premateur electrical failure to vital engine electrical parts, causing vehicle to stall intermittedly. A recall has been in place since 2002, approximately 1.3mil vehicles are affected, call your local honda/acura dealer for info and possible free repair or replace the ignition switch yourself. Hopefully my info helps you!!
SOURCE: 2004 acura Tl cruise control wont engage
This is a problem you will to take to a shop, If you are mechanically inclined I can help you, but if not I would not mess with it, it could be the button or it could be the controller and could even just be a fuse, check the fuse and if you don't find the fuse blown then let me know if you have a volt meter and what to test this yourself. You are going to be working around the air bag too and if you probe the wrong wire while testing you could break your arm or leg by deploying the air bag by accident. Or your neck.
SOURCE: I have a 2001 Acura 3.2 TL headlight goes on and off
As with Laurenson 538, I have the same problem with my 2001 CL.
Should this problem with the 2001 Acuras be a recall issue? I, too, have replaced the headlight assembly ($1,000 plus). The old one (sealed[?]) had moisture in it... the reported cause of the light burning out. Within a short period, the $1000 replacement had moisture in it and has just burned out again.
Now, at a different Acura agency, I'm told that the bulb needs another $1,000 replacement. When I asked about the warranty, I was advised 90 days was the warranty. When I asked if I was expected to spend $1,000 every 90 days to be able to drive the car, the rep got defensive.
Writing Acura resulted in a big Zero. Before buying a new Acura, one might inquire about the headlights. Since one can't drive without headlights, maybe Acuras should be reserved for daylight driving only! Have a backup car for night driving!
