Question about Toshiba 36A50 36" TV
Toshiba scan channel universal remote - Toshiba 36A50 36" TV
1 Related Answer
Ironfist109
Iron
  • 3018 Answers
SOURCE: I lost the remote to
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jul 20, 2011
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
My rca remote turns the toshiba tv on but it dont change channels
U are using an RCA remote with Toshiba tv. You are lucky that it even turns the set on. You have different remote frequencies involved and need to use the Tosiba remote or a universal remote that will operate volume, channels and power.
Mar 17, 2015 | RCA Televison & Video
I have toshiba model CT-90325 . When i type in a channel number such as 25. It goes to a different channel such as maybe 27 or 42. Sometimes when i use the up arrow channel key, it will go in order for a...
Hello... It sounds like you need to run a channel scan. If you have the owners manual, it should walk you through how to do that. I searched online for one, but couldn't find one. I seem to remember something like "Terrestrial" for Auto-programming channels. I hope this helps!
Nov 17, 2017 | Toshiba Televison & Video
I lost my Original Toshiba remote control for my TV and I need to do a channel scan that is in the setup menu, but the TV itself doesn't have a setup button to push to access the scan function, How...
You can buy a universal remote, any best buy will carry one, I have even found cheap ones at dollar tree or dollarama. They come with a manual with the codes for the make of your TV just follow the coding instructions until you find the one that will operate your TV.
Good luck
Jan 19, 2018 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
I tried to program my Toshiba TV Model 27A43 to a new Universal Remote, because the original Toshiba remote was functioning more+more slowly ( I changed batteries on the original Toshiba remote first)...
Yes do a complete new channel scan. Play this like you just got the TV. If you want to buy the OEM factory remote you can most likely get it at the link and avoid all this hassle. Follow the link below. 1 800 Remotes
Mar 28, 2017 | Vacuums
I lost my remote and only need it to set the TV to channel 3 for cable. Is there any way to do this manually?
If you are able to access menu and channel setup, you can go into autoprogram and it will scan all available channels and store them.
Otherwise you can get a cheap universal or even original replacement remote
Oct 22, 2009 | Toshiba MD14FN1 14 in. TV/DVD Combo
What is the Remote Control Code for FLX1510
taken from their support f&q section word per word
"try the following codes 10019, 0178, 10178, 0030, 10030, 0835, 10835, or for Dish Network try 627, 659 or 505. For Fios TV (Verizon), try the code 3264. These codes may not work on some universal remotes. If there is another code listed for Element Electronics in your universal remote control guide, please try that code. Refer to the Remote Control Guide under your TV’s model number for more information."
Oct 01, 2009 | Element Electronics FLX1510 15.4 in. LCD...
Toshiba 27a45
yes a universal remote will work but you may need to try several to find one that will, not all work to select your inputs. first try changeing the channel below channel 2, thats were most tv inputs are located (accessed)..
Jul 20, 2009 | Toshiba 27A45 27" TV
Can't see my cable channels!
you have to scan threw the tv in the menu to get the channels to show up
Jun 04, 2009 | Toshiba MD13P1 13 in. TV/DVD Combo
Toshiba 36A50 36" TV Logo
102 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
