Can't
SOURCE: torpedo heater ignites and then goes out reignites, goes out, etc.
We need to know more. Is this a kerosene or a propane fired heater?
SOURCE: heater will not run
You don't say, but I am assuming that the motor is running and there is combustion in the combustion chamber and the heater is running fine, then the reset trips. Is this correct? If so, chances are the Safety Control (reset) is defective. Part number HA3003. The photocell could also be at fault. Check for a dirty lense on the photocell.
But---If there is no combustion in the chamber, then the photocell detects a no-flame condition and then it trips the reset.
Troubleshooting tips for a Spark Plug type heater
SOURCE: I have a 100,000 btu reddy heater, and every time
If it actually ignites and burns but shuts off either the flame sensor is bad (or dirty) or the control is bad. I would verify the flame sensor is clean and had good electrical connections to the controller for starters.
SOURCE: pops reset botton after a few min.
Clean any photocell eye this unit may have. If it continues, replace reset control.
