Question about Goodmans GMP33000S MP3 Player
GMP33000S WHEN SWITCHED ON I GET THE MESSAGE PLS create LIB but when i press the menu button twice as per the manaul nothing happens, i pressed the reset button but when switched back on the message is still the same. the computer issues a drive number to it but unable to download to it and windows media player 10 does not reckonise it.
Posted by popps1 on
Anonymous
Hi, I had the same problem, MiMusic wouldn`t even recognise there was a disk connected although I could see it in My Computer.Found the answer on internet.
Attach it to your p.c. Then go to My Computer and highlight it. Right Click it and a box will appear . Go to FORMAT and format it. Another box will appear and ask if you really want to do it as data will be lost. Answer YES. Then format it. Disconnect from your p.c. Turn it on and you will be able to access the menu facility. Follow the instructions and goto CREATE LIB, BEFORE you put any music on to the thing.
I found it created library as soon as I disconnected it. BACK UP anything you have on it first as it will be wiped. It is working perfectly now and MiMusic is too. Yippee. Pat.
Posted on Nov 28, 2007
Why does my Polaroid z340 can t print?
On page 52 of the manual it says, press print to enter the print menu or when you want to print the last picture you took, press the print button twice.
May 02, 2014 | Polaroid Z340 3 X 4 inch Instant Digital...
Nespresso descaling
Make sure the machine is ON and you have power, then proceed as per instructions.
Jan 12, 2014 | DeLonghi Coffee Makers & Espresso Machines
When I go to make the settings - as per manual it comes up P1 3:20, but when I press the 'menu' button nothing seems to happen. I expected to see P2, P3 etc so my white bread (P1) is terrific
Sometimes the little buttons underneath are not centered properly. Try pushing around the edges of the "menu" selector button your machine makes a "beep" sound" If you never feel the button move under your finger followed by the "beep" sound then your selector menu button may be broken.
Apr 16, 2013 | Russell Hobbs 18036 Breadmaker Fresh Bread...
"toner life end" message even with new cartridge
Open the front cover
Press the OPTIONS button
Press the START button
Press the number 1 key twice
Close the front cover.
You may need to go through the steps above twice to reset the toner.
Jul 11, 2010 | Brother IntelliFax-2820 Laser Fax
"Page Too Complex" message
Press ENTER to clear the message.
Allow the device to finish the job, or press CANCEL to cancel the job.
Lower the USB speed on the product by turning off "High Speed USB". Following are instructions on how to do this from the Secondary Service Menu:
To access the Secondary Service Menu press the Menu button.
Now press the #2 button and use the < arrow to navigate to the High Speed USB selection.
Press Enter and then use the arrow key to go to Off and press Enter again.
Press the Cancel button twice to exit the Secondary Service Menu.
Feb 15, 2010 | HP LaserJet 2840 All-In-One Printer
Changing the answering setting from AO back to recording message
Manual says to press "change", then "setup" until...(it comes out to pressing it twice), then use "repeat" or "skip" to get to the one you want (A,B, or AO), then press the "Mbox 1" or "Mbox 2" button.
Dec 05, 2008 | AT&T 9350 Cordless Phone
Paper tray full message and not printing
there is a black tab in the center where the papers come out that is the tray full sensor arm that is more then likely stuck
Dec 26, 2007 | Kyocera FS-4000DN Laser Printer
How to delete pictures
you can just use the format menu on the setup menu
Dec 13, 2007 | Sony Cybershot S650 Digital Camera
Player does not play
Jul 07, 2007 | Goodmans GMP33000S MP3 Player
Goodmans GMP33000S MP3 Player Logo
148 people viewed this question
Top Goodmans Audio Players & Recorders Experts
Pavel Pranovich
Pavel Pranovich
Tom Chichester
Larry
Are you a Goodmans Audio Player and Recorder Expert? Answer questions, earn points and help others
