Trying to play back a dvd recorded from the computer but the dvd player will not play it
SOURCE: Sansui VRDVD4005 DVD Player /
did u double chek the dvd-rw maybe the r corrupetd
if its not the faulty: the burn processor is damaged try u need to replace it
SOURCE: DVD PLAYS CD'S BUT WONT PLAY DVD'S
Aquarius0128 there are two things to consider here.. dvd's recorded on a computer need to be closed/finalized after you have recorded onto them in order to be used on a stand alone player.. they will play ok on original recorder because of the design of these machines finalizing prepares the structure of the disc so it can be recognised by other players as a dvd video disc.. you will usually see a 'finalize disc' option in your recording program
Second issue is this.. even if finalized an older (or even some modern) stand alone players will not recognise a recorded disc made on a computer or even if it can there are different formats DVD+R DVD-R and even DVD-RAM and DVD-RW (the two latter ones are rarely recognised outside a computer)
SOURCE: Sansui DVD Vcr combo wont play Dvd's model no. VrdVD4005
either the lens is weak in your dvd player or the get your cd checked in another dvd player to confirm the doubt.what exactly has problem.the player or the disk. thanks.
SOURCE: Have a Sansui VCR/DVD player/recorder.
Google the term "Sansui/the model number/manual." A lot of hits will come back, likely a number will have a free downloadable copy of the owners manual.
SOURCE: My DVD recorder will not recognize any of the DVDs
yes, that is the solution... try to get the DVD that is 4x (Maxell, Dynex) most are all up to 16x now... unless you can find a firmware update for Sansui (I tried already for you, but you can with out a doubt try too)
