Question about Kenmore 57029 Side by Side Refrigerator
Kenmore side by side 51073 refrigerator frost on back wall and uneven freezing in freezer
5 Related Answers
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
Amigaman
Gerald Griffin
  • 248 Answers
SOURCE: Frost buildup
  It is not defrosting.  You have to remove back wall of freezer where frost is and take hairdryer to melt away frost.  You need to check defrost heater.  This is on bottom of evaporator coils.  It has wires going to it on both sides.  This has to be checked for continuity.  If ok on top of coils is a round unit called a defrost terminator.  This needs to be checked for continuity also.  This must be done before you defrost coils.  It should have continuity when its cold.
  If these are ok you probably have a bad timer or defrost board.
Posted on Oct 25, 2007
Anonymous
  • 1122 Answers
SOURCE: Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Posted on Jun 17, 2008
22yooper
James Helmer
  • 828 Answers
SOURCE: kenmore sideby side fridge
You have a defrost system problem. Defrost is controlled by a timer which energizes the heater circuit. The heater circuit has a radiant or cal rod type heater which melts the frost from the coil. When the coil reaches a temperature where all ice would be gone a termination switch opens and shuts of the heater. The timer will continue to run until defrost time expires (18-22 minutes).
If you can locate the timer there is a clutch head screw to advance the timer to the defrost position. Turn the screw clockwise SLOWLY until you hear one audible click. The heaters should come on and defrost take place. If the unit restarts after the 18-22 minute period the timer is good, if it does not restart advance the screw to a second audible click and it will restart.
If you had to turn the timer the to second click to get it started cooling replace the timer.
If the unit restarted after the 18-22 minutes and defrost did not happen your problem is in the heater circuit. This would be an open heater or bad defrost terminator switch. To access the heater and defrost terminator the back panel in the freezer section must be removed. With an Ohm meter you can check the heater to see if it is good.
Posted on Jul 02, 2008
gaeb7
Dennis Gaebel
  • 36 Answers
SOURCE: Frost build up in the freezer section of my side by side Kenmore
Replace the defrost clock.
Posted on Feb 25, 2009
Freezer gets fool of frost on walls of freezer only
if its both sides and the top... possible causes; door not sealing all the way around, icemaker stalling and heating raising temp in freezer, or the airflow is blocked.... if it is frosting only on the back wall its a defrost issue..... more info is needed to narrow this down for you
Oct 09, 2014 | Kenmore 64802 Top Freezer Refrigerator
My kenmore refrigerator freezer works but the refrigerator does not get cold
is the fan running on the freezer side?? look to see if you have frost on the back wall of the freezer .... if you have frost then your not defrosting
Apr 02, 2011 | Kenmore Refrigerators
I have a Kenmore, side by side, with ice cubes-crushed-and water, color-black. My problem started with the refrigerator side not being very cold, now the freezer side is not freezing. The fan is blowing...
you said a lot . the frost in the freezer back would let know that you have a defrost problem . no frost means no frost . so the heater or the terminator have failed . the unit needs to be defrosted of ice and the heater cked and if bad replaced and always replace the terminator . orthe cause is the a d c adapitive defrost control . ,, mm
Aug 20, 2010 | Kenmore Refrigerators
Maytag mzd2666geq refrigerator does not freeze - both freezer and refrigerator - it started yesterday afternoon. There is a lot of ****-frost on the freezer back wall. Evaporator motor is running (I...
REMOVE THAT FROST WITH A HAIR DRIER. THIS SHOULD MAKE IT WORK FOR UP TO 21 DAYS. THERE IS A 95 PERCENT CHANCE THE ADAPTIVE DEFROST CONTOL IN THE CEILING OF THE FRESH FOOD SECTION HAS FAILED. YOU CAN ORDER THE PART AT...
http://www.searspartsdirect.com/partsdirect/index.action
Apr 23, 2010 | Maytag MZD2766GES Side by Side...
The freezer will not freeze, but refrigerator side is workingfine
the freezer back wall need to be open and check the heat element and the thermostat , also make sure the fan is working in the freezer. if the frost on the coils are not even then it is sealsystem that is bad news, but if it is just frozen defrost it with hair dryer and check the elements i told you to check
Dec 30, 2009 | Kenmore Refrigerators
The freezer side not freezing just cool, the
Open freezer door, pull food off shelves on lower half of inside freezer and look if you have frost building up on the back wall of freezer. If you do then you have a defrost heater or thermostat possible gone bad.
Advise if you have frost build up and I will advise on how to check it.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fridge side not working freezer frost on back at first now not freezing hardly at all
If you still have the frost build up on the back wall of the freezer, your problem is in the defrost circuit. You'll find a bad heater, terminator or control.
Also verify operation of the evaporator (freezer) fan.
Apr 29, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Model 57572791 not cooling or freezing on either side
IF YOU LOOK INTO FREEZER BACK WALL CAN YOU SEE HEAVY FUZZY FROST?
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore frost free refrigerator
Hi thanks for te question .If all the coils are frosted. no its not going into the defrost cycle. and you also have a problem with a clogged drain thanks the appliance doc
Sep 18, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Amana frig
1.Dirty condenser coils where heat is transfered to the room air. 2.Frost build-up on back wall of freezer section which would indicate a defrost system problem.
May 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 57029 Side by Side Refrigerator Logo
108 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
