Question about Pride Mobility Products Health & Beauty
Celebrity xl8 wont go does 3beeps/1beep
Checked motor / brake wireing/connections batts read full lights and every thing else works fine just beeps does release brake or any thing help please
2 Related Answers
GodBlessU
Aparajita Batabyal
  • 3513 Answers
SOURCE: pride legend xl8 scooter electrical harness
First take the control panel off, (panel that has the battery power display etc ) take care in doing to make sure you don't pull any wires off.
first check the wiring on the ignition switch, check the speed pot by moving it up and down,
Check the connections to the battery follow the wires from the battery to the Motor controller, normally marked B+, B-, then follow from the motor controller to the motor again checking the connections.
Make sure the freewheel lever stays in position
Please check the link bellow to diagnose your problem:
http://www.pridemobility.com/pdf/Owners_Manuals/INTL_Scooter/uk/UK_Legend_Classic_XL_8_om.pdf
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 04, 2010
Ironfist109
Iron
  • 3018 Answers
SOURCE: new batterys fitted from lucas
  • Well when the battery clicks like that it is an indication of either a loose connection of the battery has died.
  • First thing is to make sure that battery got a real good charge first before using the scooter. half a charge won't do much especially being new.
  • Now if some of the metal plating has come off of the connector it is possible the connection is not quite doing it at that point. Imagine how a car sounds when you try to start it and the battery clamp has come a tad loose... click click click click click.
  • In this case you need to try a new connector. You can try the place you got the gogo scooter from or this place sells many scooter parts http://www.monsterscooterparts.com/mobility-battery-chargers.html
  • Make sure the fuse is good and check all wiring for a direct short. Make sure non of the insulation has been negated.
  • Get out a multi-meter and set it to DC and start testing the power feed wires for 12v DC power. Check the ground wire as well and make sure the polarity is 0. If the is polarity in the ground wire anywhere then there is a short somewhere for sure. Start at the connector and move down.
  • Make sure the battery charging unit/cables are functioning properly as well. If the charger is not charging properly it would be hard for the battery to perform properly.
  • Hope this helps and thanks you for using FixYa.
Regards, Tony
Posted on Jun 14, 2011
HUSBAND FLIPPED HIS PRIDE CELEBRITY X SCOOTER STOOD IT STRAIT UP IN THE AIR.NOW NOT WORKING.5 FLASHES
Five beeps? Maybe it's not the same as my Celebrity XL8 but my instruction manual talks of a 1+4 beep warning meaning low battery charge. It also suggests checking that the wiring harness connectors are all fully connected - that would include the battery terminals of course. If your hubby managed to do a wheelie this sounds a strong possibility if the batteries were dislodged. Anyway, I attach the page from my Celebrity XL8 manual, you can find other Celebrity manuals online. My congratulations to your husband, I've yet to master wheelies!
Jun 13, 2017 | Pride Health & Beauty
Pride Celebrity XL8 - problem with right side indicators
hi Stuart, have you check out the actually switch that you pressed to activate the indicators ?
Regards
Rob
Apr 18, 2016 | Pride Health & Beauty
Celebrity XL8 not engaging then sticks in forward motion. Gives fault code of 4 beeps then 1. Code sequence not covered by manual.
hi Pete, okay there can be one of two reason for that fault.
1. check the motor wiring from the controller to the motor and if possible check the resistance of the motor by checking the brushes, if you have a smart meter disconnect the motor wires from the controller and take a resistance reading we looking at around 0.3 to 1 ohms.
2. Controller fault , i can test the controller for you free of charge , you simply pay the return postage..
Regards
Rob.
Jan 25, 2016 | Health & Beauty
Air con switches of when on heating then starts beeping 1beep 2beeps 3beeps
Some units emit a flashing code. Check your manual to see if the flashes represent a fault code.
Apr 22, 2014 | LG Heating & Cooling
Taken out cmos and ram sticks,switched on and still gives 3beeps,3beeps,1beep
Try to change your RAM . Or if u have more than 1 RAM try to isolate the problem by putting in the 1st stick then try to boot it up. Hope it helps
Nov 22, 2013 | Fujitsu AMILO Pro V2055 PC Notebook
3 beeps 3beeps 1beep
The beep codes indicate the battery is discharged - and needs to be recharged. A manual can be downloaded at http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/LIFEBOOK/AMILO/AMILO-Pro/Downloads/a26391-k183-z121-en.pdf
Nov 22, 2013 | Fujitsu Siemens Amilo Pro V2055 V2030...
My hard drive doesn't boot up as normal. When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps. Numbers 3 and 4 on the hard drive are...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 29, 2010 | Computers & Internet
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
Pride "Celebrity XL Deluxe" 4-wheeled Mobiltiy Scooter
Sounds like your motor brake is out. Usually the discolor on the brake indicates it has overheated.
Apr 12, 2009 | Pride Value Line Revo Scooter 3 Wheel
Health & Beauty Logo
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
