Question about Epson RX620 All-In-One InkJet Photo Printer
Cannot change paper type from photo to plain on Epson XP-312
4 Related Answers
Anonymous
  • 97 Answers
SOURCE: My printer no longer feeds in Epson Premium Glossy paper S041624
Try to clean the paper pick rollers with a cloth, dam it with little water and try to hange the paper settings by going into printer preferances.
Regards,  raj_p5983
Posted on Jan 20, 2009
virtualhost
virtualhost
  • 2185 Answers
SOURCE: Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Posted on Sep 20, 2009
Testimonial: "tried blowing and dusting with a brush Now it comes on as normal - no flashing light but will only take paper about 2 cms then flashes paperjam"
bschilz
Bill Schilz
  • 2049 Answers
SOURCE: Does the Epson Stylus Photo R340 Printer print non photo document
It will print in plain text if your document is in plain text.
If the document uses a font, it will print using that font.
That being said, if you have Print Quality in your Printer Preferences set to Text/Graph instead of Automatic Standard or Automatic High Quality, it will ignore the fonts and print as plain text.
You can adjust it by going in to Control Panel, selecting Printers, right clicking on your printer and choosing the Advanced tab to reset the Print Quality.
Posted on Dec 03, 2009
Salim Baig
Saleem Baig
  • 283 Answers
SOURCE: plain paper feeds no problem
Hi
This looks to be a problem with the paper pickup roller. Hence use a little thin Photo paper or replace the Pickup roller and also the Paper feed toller (Long black roller )
Posted on Jul 15, 2011
How to change paper from photo to plain on Epson Stylus nx430, the side arrows have disappeared.
You can't change the paper type on the printer itself. You need to go into the document and when you select the printer to use, you will see printer properties. You should be able to change paper type on that screen.
Jan 17, 2018 | Epson Office Equipment & Supplies
How to change from photo to plain paper on settings on Epson SX445W
This question has not been answered. Has anyone figured out how to change the 'Paper Type" setting in the copy menu from photo paper to normal paper? Also how do I change the quality setting from "standard quality" to draft etc.
Jun 28, 2012 | Office Equipment & Supplies
My R1900 is over 1 year old. Profiles are set for Epson glossy and matte paper. Epson ink is used. Colors are now very green when printing to glossy or matte paper. However, if I use the plain paper...
The difference in choosing the paper type will have an impact on how head squirts ink onto the media. For Epson printers, the best choice to fit the color is plain paper.However, to the maximum dpi (best photo or photo rpm), plain paper does not support.This can be overcome by adjusting the color management of the program that we use.Or convert to bitmap all objects (such as Corel Draw), or also in print as bitmap option.
Feb 22, 2011 | Epson Stylus Photo R1900 InkJet Printer
Epson SX5400... accepts regular plain paper just fine but jams with Glossy Photo papter
That is because you need to change the settings on your printer to the type of paper your using.
Hope this helps!
Feb 06, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Cheers.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Photo printing is too dark. I have replaced all print cartridges and it still prints too dark. Thanks for your help.
did you choose the right profile for your printing profile also means the type of media or paper you are using for example is it a photo paper or is it just a plain paper, you have to choose, or else this type of problem will occur.
Sep 12, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
921 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
