Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
Zoom lever (Olympus Camedia C-8080 Wide Zoom Digital Camera ) does not work
Zoom lever  does not work nothing happens when you move the lever
Posted by Don C on
Steven Wander
  • 594 Answers
If you can get to the ribbon cable that the zoom lever is attached to, you can use a multimeter or a continuity tester to see if the lever is actually shorting any traces on the ribbon. the zoom lever acts upon a motor that rotates the iner lens barrel, possible the motor lead is open or the switch under the lever is dirty/faulty.
Posted on May 11, 2008
I NEED THE REFERENCE MANUAL FOR C-8080 WIDE ZOOM CAMEDIA
you can download it at http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c8080wz_e.pdf
Aug 30, 2012 | Olympus Camedia C-8080 Wide Zoom Digital...
Olympus c-8080 will not power on, batteries were charged one new tried both but press power and nothing happens
Either the batteries are completely shot (shorted out) or the orientation of the batteries is incorrect. Make sure they are facing the correct direction. Otherwise, you'll need to take your camera to a repair shop for troubleshooting. In the case of a consumer-level camera like this one, you probably will end up with a repair estimate that would exceed the value of a new camera. Good luck!
Mar 10, 2011 | Olympus Camedia C-8080 Wide Zoom Digital...
Zoom Won't Work
The motor has failed I guess Check the Olympus site for advice re repair or replacement.
Aug 12, 2007 | Olympus Camedia C-725 Digital Camera
Sound recording and playback
Yes, the camera has a built-in microphone and a built-in speaker.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Connect an flash and aftermarket bracket
When using an external flash with the C-8080 Wide Zoom, you will need the appropriate flash cable with your flash and aftermarket bracket. The Hot Shoe Flash Cable (FL-CB05) mounts to the C-8080 Hot Shoe and the opposite end attaches to the aftermarket flash bracket’s flash shoe or to a standard tripod attachment thread (1/4x20).
Connect an FL-20, FL-36, FL-40 or FL-50 external flash
The FL-20, FL-36, FL-40 or FL-50 external flash can be attached directly to the hot shoe on the camera. You also can use the FL-BK01 Flash Bracket and the FL-CB02 Hot Shoe to TTL cable.
PictBridge
PictBridge is a specification announced by six private companies: Canon, Fuji, HP, Olympus, Seiko Epson and Sony, in December 2002. Its aim is to allow for direct printing between various brands of digital still cameras.
Panorama feature
Yes, the panorama feature is available provided that you use an Olympus brand xD-Picture Card.
IESP auto focus
iESP is the default auto focus setting for the C-8080 Wide Zoom camera. It uses a contrast detecting system to analyze the entire image by comparing the subject against the background to achieve focus. When the shutter button is pressed half way on the C-8080 Wide Zoom, the AF target mark automatically moves to an area of the image where it finds the optimal contrast.
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
286 people viewed this question
Top Olympus Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you an Olympus Camera Expert? Answer questions, earn points and help others
